MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0005507 | ParaView | (No Category) | public | 2007-08-15 17:26 | 2007-08-21 11:58 | |||||
| Reporter | Ken Moreland | |||||||||
| Assigned To | Clinton Stimpson | |||||||||
| Priority | high | Severity | minor | Reproducibility | always | |||||
| Status | closed | Resolution | fixed | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | ||||||||||
| Target Version | Fixed in Version | |||||||||
| Project | ||||||||||
| Topic Name | ||||||||||
| Type | ||||||||||
| Summary | 0005507: Out-of-order keyframes | |||||||||
| Description | The Animation Keyframes dialog box allows you to set arbitrary values for the time of each keyframe. This is good, but results in the possibility of keyframes that are out of order. The keyframes should be reordered whenever the time of one is moved outside of the range of the surrounding keyframes. The correct interpolation used becomes a bit ambiguous. Just pick values that make sense based on the existing interpolation. They are easy enough to change if they are wrong. | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2007-08-15 17:26 | Ken Moreland | New Issue | ||||||||
| 2007-08-15 17:26 | Ken Moreland | Relationship added | related to 0003340 | |||||||
| 2007-08-15 17:28 | Ken Moreland | Assigned To | => Clinton Stimpson | |||||||
| 2007-08-15 17:28 | Ken Moreland | Status | backlog => tabled | |||||||
| 2007-08-20 14:34 | Clinton Stimpson | Status | tabled => @80@ | |||||||
| 2007-08-20 14:34 | Clinton Stimpson | Resolution | open => fixed | |||||||
| 2007-08-20 14:34 | Clinton Stimpson | Note Added: 0008525 | ||||||||
| 2007-08-21 11:58 | Ken Moreland | Status | @80@ => closed | |||||||
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | |||||||
| Notes | |||||
