MantisBT - ParaView |
View Issue Details |
0005384 | ParaView | (No Category) | public | 2007-07-23 10:40 | 2009-05-13 13:59 |
Reporter | David Karelitz | |
Assigned To | Utkarsh Ayachit | |
Priority | normal | Severity | major | Reproducibility | always |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | 3.4 | Fixed in Version | 3.4 | |
Project | |
Topic Name | |
Type | |
Summary | 0005384: Selection and ExtractCTHParts |
Description | Selection does not work on the output of extractCTHparts.
This is with an AMR CTH dataset using the cvs trunk from monday of last week.
I can draw the selection box, but the pink mesh doesn't show up and nothing is shown in the element inspector.
I then tried to cut/slice the dataset. When I select cells on the cut plane, the pink selection shows up, but the wrong cells are selected and nothing is shown in the element inspector. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | |
2007-08-13 14:54 | Berk Geveci | Note Added: 0008428 | |
2007-08-13 14:54 | Berk Geveci | Priority | high => normal |
2007-08-29 15:13 | Berk Geveci | Note Added: 0008751 | |
2007-08-29 15:13 | Berk Geveci | Assigned To | Berk Geveci => Dave DeMarle |
2008-04-09 21:16 | Berk Geveci | Assigned To | Dave DeMarle => Berk Geveci |
2008-04-09 21:16 | Berk Geveci | Category | => 3.4 |
2008-04-23 12:05 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-23 12:05 | Utkarsh Ayachit | Resolution | open => no change required |
2008-04-23 12:05 | Utkarsh Ayachit | Note Added: 0011508 | |
2008-04-29 21:45 | Alan Scott | Status | @80@ => @20@ |
2008-04-29 21:45 | Alan Scott | Resolution | no change required => reopened |
2008-04-29 21:45 | Alan Scott | Note Added: 0011592 | |
2008-04-30 09:40 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-04-30 09:40 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-04-30 09:40 | Utkarsh Ayachit | Note Added: 0011598 | |
2008-04-30 09:40 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-04-30 09:40 | Utkarsh Ayachit | Status | @80@ => @20@ |
2008-04-30 09:40 | Utkarsh Ayachit | Resolution | fixed => reopened |
2008-04-30 09:41 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-04-30 09:41 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-01 17:57 | Alan Scott | Status | @80@ => closed |
2008-05-01 17:57 | Alan Scott | Note Added: 0011660 | |
(0008428)
Berk Geveci
2007-08-13 14:54
This will be done in 3.4 when multi-block selection is working. |
(0008751)
Berk Geveci
2007-08-29 15:13
This is probably a duplicate. Selection of multi-block does not work yet. |
(0011508)
Utkarsh Ayachit
2008-04-23 12:05
This should work now, selection on composite datasets is now supported. |
(0011592)
Alan Scott
2008-04-29 21:45
Sorry, doesn't work.
XP client/ server (6 pvservers)
Using CTH data from dave, spcta_a.0.
Load all cell array variables. Accept.
Filters/ Extract CTH Parts.
Unselect Material volume fraction - 2, leave everything else as default.
Apply.
Select Cells On, try to rubber band select the object. Cells are selected randomly - on the back of the object.
Select Cells through, and select points all work. |
(0011598)
Utkarsh Ayachit
2008-04-30 09:40
Ah--the selection was having problems since the data has ghost cells. There was a bug in geometry filter which removed ghost cells before assigning original ids. Consequently original ids were wrong and hence selection mechanism would end up selecting incorrect cells. Fixed that.
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGeometryFilter.cxx,v <--
new revision: 1.80; previous revision: 1.79 |
(0011660)
Alan Scott
2008-05-01 17:57
