(0007935)
Berk Geveci
2007-06-26 09:58
I am assuming you have a series of files, such as foo001, foo002,... We will add support for file series in 3.2. In 3.0, time/animation works only with readers that natively support time. |
(0008615)
Berk Geveci
2007-08-23 10:44
I guess the AVS UCD reader does not support time. Someone should add that support. It is not a high priority for us. |
(0011243)
Berk Geveci
2008-04-09 21:01
This is super easy to fix. Adding to 3.4 list. |
(0012713)
Utkarsh Ayachit
2008-07-15 13:01
Added support for reading file series to AVS UCD reader.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/readers.xml,v <--
new revision: 1.127; previous revision: 1.126
/cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewReaders.xml,v
<-- Qt/Components/Resources/XML/ParaViewReaders.xml
new revision: 1.25; previous revision: 1.24 |
(0012840)
Alan Scott
2008-07-28 18:46
Tested local client only. I copied 5 version of the same file, using cellsnd.bin.inp from the VTK data. Seems to work. |
