MantisBT - ParaView
View Issue Details
0004355ParaView(No Category)public2007-01-22 19:232011-01-14 20:35
Ken Moreland
Clinton Stimpson
lowmajoralways
closedfixed
Someday
0004355: Linked properties do not update GUI
When two objects are linked and the master object is changed, the slave object is properly updated, but the slave's associated GUI still shows the old values.
No tags attached.
Issue History
2008-04-07 16:43Berk GeveciNote Added: 0011120
2008-04-07 16:43Berk GeveciStatusbacklog => tabled
2008-04-07 16:43Berk GeveciCategory => 3.4
2008-05-01 13:35Berk GeveciCategory3.4 => 3.6
2009-02-16 14:48Ken MorelandCategory3.6 => Someday
2009-05-13 13:49Utkarsh AyachitTarget Version => Someday
2011-01-14 13:52Utkarsh AyachitNote Added: 0024687
2011-01-14 13:52Utkarsh AyachitStatustabled => @80@
2011-01-14 13:52Utkarsh AyachitResolutionreopened => fixed
2011-01-14 20:35Alan ScottNote Added: 0024699
2011-01-14 20:35Alan ScottStatus@80@ => closed
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0006249)
Clinton Stimpson
2007-01-23 16:39
/cvsroot/ParaView3/ParaView3/Qt/Core/pqPropertyLinks.cxx,v <-- pqPropertyLinks.cxx
new revision: 1.5; previous revision: 1.4
(0006358)
Ken Moreland
2007-02-05 19:27
The linked object's GUI is updated only after Apply is hit. Is it possible for the GUI to be updated immediately?
(0006751)
Clinton Stimpson
2007-03-12 18:12
That would probably require a global pqPropertyManager instance for the whole GUI, instead of local instances.
(0006955)
Clinton Stimpson
2007-03-27 12:17
Note to self: Actually, better fix would be to have a global pqPropertyManager::pqInternal::PropertyMap would probably fix this without changing any code elsewhere in ParaView.
(0011120)
Berk Geveci
2008-04-07 16:43
Is this an issue? Fix if it is very easy to fix. Otherwise, put off until someone asks for it.
(0024687)
Utkarsh Ayachit
2011-01-14 13:52
pretty sure this is fixed now.
(0024699)
Alan Scott
2011-01-14 20:35
I also believe that this is fixed. If not, please give directions on how to test.
