(0005760)
Clinton Stimpson
2006-11-22 15:21
/cvsroot/ParaView3/ParaView3/Qt/Components/pqClipPanel.cxx,v <-- pqClipPanel.cxx
new revision: 1.14; previous revision: 1.13
(0005809)
Ken Moreland
2006-11-27 13:24
The widget still is not behaving correctly. Right now, the transparent polygon is turned on when the widget is first created and when the user starts interacting with the widget. The polygon is turned off when the user stops interacting with the widget.
The turn on behavior is currect, but the turn off behavior is wrong. The polygon should remain on after interaction stops, and should be turned off after the "Accept" button is hit. |
(0005812)
Clinton Stimpson
2006-11-27 14:25
Ok, what I did was make clip behave like cut. So I'll change both of them.
(0005813)
Ken Moreland
2006-11-27 14:27
Yes, good. Clip and cut should both behave as I described above. |
(0005816)
Clinton Stimpson
2006-11-27 15:16
new revision: 1.15; previous revision: 1.14
/cvsroot/ParaView3/ParaView3/Qt/Components/pqCutPanel.cxx,v <-- pqCutPanel.cxx
/cvsroot/ParaView3/ParaView3/Qt/Components/pqImplicitPlaneWidget.cxx,v <-- pqImplicitPlaneWidget.cxx
new revision: 1.9; previous revision: 1.8
/cvsroot/ParaView3/ParaView3/Qt/Components/pqImplicitPlaneWidget.h,v <-- pqImplicitPlaneWidget.h
