Description | Trying to read an "empty" VTK-File (either file or string input), e.g. the representation of an empty vtkPolyData object (no points, no cells, just the header), a test app crashes inside the read operation. The reason for this is the "new" STL-implementation shipped with .NET2005. A lot of calls there are using assertions to ensure proper input parameters. In particular istream::read(*readbuffer,numbytes) now asserts that the input read pointer be != NULL. This caused the crash mentioned above, since eventually a NULL pointer is passed to read (in template <class T> int vtkReadBinaryData(istream *IS, T *data, int numTuples, int numComp)).
In the "old" STL implementation this was no problem. A NULL-pointer was only passed to calls which didn't read anything from the istream either, so in effect nothing was written to the invalid address. I include a possible fix for this here, introducing a sanity check into vtkReadBinaryData in vtkDataReader.cxx, resulting in the code attached to this report.
I got this problem with vtk4.2.6 but it does not seem to be fixed in vtk5 either. Moreover, it is likely that this does not only apply to empty polydata but also to other (empty) data object classes because the respective reader classes also rely on vtkDataReader's functionality.
BTW: Nobody seems to care about the return value of vtkReadBinaryData. I don't know if this should be called a design issue. |
