(0003821)
Andrew Maclean
2006-03-01 20:09
As I suspected the solution is not as simple as outlined below, just doing memcpy(&this->Internal->Data.end() - length, data, length);
causes other errors. |
(0003822)
Andrew Maclean
2006-03-01 20:23
But this works:
memcpy(&*(--this->Internal->Data.end()) - length + 1, data, length);
However we run into the same problems at int vtkClientServerStream::ParseData() in line 1205.
This section of code will definitely need a rewrite. |
(0007779)
Berk Geveci
2007-06-02 09:39
(0007925)
Andrew Maclean
2007-06-24 20:08
Everything compiles Ok with Paraview 3. I finally got around to installing QT 4.2.3
So I think you can close this bug.
Andrew |
