(0003363)
2005-12-06 18:08
Not able to reproduce this, if I create two new connections, I get a warning message "Warning: In \src\ParaQ\ParaView\Vtk\Parallel\vtkSocketController.cxx, line 63
vtkSocketController (0546C3B8): Already initialized.", but the app continues to work. |
(0003364)
Timothy Shead
2005-12-06 18:09
(0003382)
Clinton Stimpson
2005-12-08 17:48
Its a memory error in the GUI. Looks like a bug in Qt which affects the object hierarchy view. |
(0003383)
Mark Richardson
2005-12-09 11:35
There is a bug in the Qt object model. If you remove an item with a sub-item selected, it does not remove the persistant index for the selection. Later, it asks for the parent of the removed, and deleted, object.
I haven't tried Qt 4.1, but there was supposed to be a fix for this. If not we may be able to work around it be deselecting the sub-item before removing it. |
(0003885)
Mark Richardson
2006-03-20 17:47
Qt 4.1 does fix the crash in the selection model. |
