MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0002206 | ParaView | (No Category) | public | 2005-09-02 04:48 | 2009-12-10 06:56 |
| Reporter | Johnny Devaprasad | ||||
| Assigned To | Berk Geveci | ||||
| Priority | normal | Severity | major | Reproducibility | always |
| Status | closed | Resolution | unable to reproduce | ||
| Product Version | |||||
| Target Version | Fixed in Version | ||||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0002206: server crashes while loading data when number of procs>2 | ||||
| Description | the server crashes with the following error messages when number of pvserver > 2, but after client connects to the server: Error message:Listen on port: 11111 Waiting for client... connected to port 11111 Client connected. Process id: 0 >> ERROR: In /home/johnny/app/paraview/paraview-2.2.1/VTK/IO/vtkDataReader.cxx, line 432 vtkDataSetReader (0x200d5e0): Unrecognized file type: ##* for file: (Null FileName) Process id: 0 >> ERROR: In /home/johnny/app/paraview/paraview-2.2.1/VTK/Filtering/vtkExecutive.cxx, line 680 vtkStreamingDemandDrivenPipeline (0x200d450): Algorithm vtkDataSetReader(0x200d5e0) returned failure for request: vtkInformation (0x200d8e0) Debug: Off Modified Time: 29862 Reference Count: 1 Registered Events: (none) ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 REQUEST_DATA_OBJECT: 1 [node01:3] Fatal Error: Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c [node01:2] Fatal Error: [node01:1] Fatal Error: Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c Unexpected disconnect received from [node01:0] at line 1698 in file vapiutil.c | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView | ||
| 2009-12-10 06:56 | Berk Geveci | Note Added: 0018791 | |||
| 2009-12-10 06:56 | Berk Geveci | Status | tabled => closed | ||
| 2009-12-10 06:56 | Berk Geveci | Resolution | open => unable to reproduce | ||
| 2011-06-16 13:09 | Zack Galbreath | Category | => (No Category) | ||
| Notes | |||||
