MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0015975 | ParaView | (No Category) | public | 2016-02-05 09:46 | 2016-08-12 10:00 |
| Reporter | Felipe Bordeu | ||||
| Assigned To | Kitware Robot | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 5.0 | ||||
| Target Version | Fixed in Version | ||||
| Project | TBD | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0015975: Problem with save state in python format (missing apply opacity to objects) | ||||
| Description | I found a bug in the latest verison 5.0.0 home compilation in linux (and binary versoiin from Web for windows) to replicate: - create a Wavelet source - change to Volume representation - change the opacity transfert function - File-> Save State -> in python format -> use default ("any *modified* properties" and "Skip Hiden..." checked) (I tested with all 4 conbination of this options) - Edit -> Reset Session - Tools-> Python Shell -> Run Script (run the just created state in python) The opacity is not applyed in the attached file the output of the Save stated with the extra line to make things work. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/10028/test.py | ||||
| Issue History | |||||
| 2016-02-05 09:46 | Felipe Bordeu | New Issue | |||
| 2016-02-05 09:46 | Felipe Bordeu | File Added: test.py | |||
| 2016-08-12 10:00 | Kitware Robot | Note Added: 0038992 | |||
| 2016-08-12 10:00 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 10:00 | Kitware Robot | Resolution | open => moved | ||
| 2016-08-12 10:00 | Kitware Robot | Assigned To | => Kitware Robot | ||
| Notes | |||||
