MantisBT - ParaView
View Issue Details
0015973ParaView(No Category)public2016-02-05 09:182016-08-12 10:00
Patrick Brockmann
Kitware Robot
normalminorhave not tried
closedmoved
5.0
TBD
incorrect functionality
0015973: filled contours with paraview, comparison with use of vtkBandedPolyDataContourFilter
I cannot produce with paraview filled contours that match to what I get with vtk python code that uses vtkBandedPolyDataContourFilter. Attached the state file.
I have also noticed that with vtk, filled bands do not follow edges extracted from the vtkBandedPolyDataContourFilter with GetContourEdgesOutput.
Could it be corrected ?
Another idea was to produce filled contours and correct edges from a vtkTriangleFilter but then you will notice artefacts due to the additionnal triangles added.
Play the python script.
You can toggle with the key 't' between use of vtkTriangleFilter or not.
Capture images with the key 'u'.
From paraview, please load the state file and try to reproduce what I get from the vtk python code. I have not succeeded.
No tags attached.
png picture_vtkBandedPolyDataContourFilter_vtkBandedPolyDataContourFilter.png (129,064) 2016-02-05 09:19
https://www.vtk.org/Bug/file/10022/picture_vtkBandedPolyDataContourFilter_vtkBandedPolyDataContourFilter.png
png
png picture_vtkBandedPolyDataContourFilter_paraview.png (62,061) 2016-02-05 09:20
https://www.vtk.org/Bug/file/10023/picture_vtkBandedPolyDataContourFilter_paraview.png
png
png picture_vtkBandedPolyDataContourFilter_vtkTriangleFilter.png (257,760) 2016-02-05 09:20
https://www.vtk.org/Bug/file/10024/picture_vtkBandedPolyDataContourFilter_vtkTriangleFilter.png
png
? bug_vtk6.3_vtkBandedPolyDataContourFilter.py (3,015) 2016-02-05 09:21
https://www.vtk.org/Bug/file/10025/bug_vtk6.3_vtkBandedPolyDataContourFilter.py
? contours.pvsm (319,922) 2016-02-05 09:21
https://www.vtk.org/Bug/file/10026/contours.pvsm
? iso.vtk (19,461) 2016-02-05 09:21
https://www.vtk.org/Bug/file/10027/iso.vtk
Issue History
2016-02-05 09:18Patrick BrockmannNew Issue
2016-02-05 09:19Patrick BrockmannFile Added: picture_vtkBandedPolyDataContourFilter_vtkBandedPolyDataContourFilter.png
2016-02-05 09:20Patrick BrockmannFile Added: picture_vtkBandedPolyDataContourFilter_paraview.png
2016-02-05 09:20Patrick BrockmannFile Added: picture_vtkBandedPolyDataContourFilter_vtkTriangleFilter.png
2016-02-05 09:21Patrick BrockmannFile Added: bug_vtk6.3_vtkBandedPolyDataContourFilter.py
2016-02-05 09:21Patrick BrockmannFile Added: contours.pvsm
2016-02-05 09:21Patrick BrockmannFile Added: iso.vtk
2016-02-05 09:28Patrick BrockmannDescription Updatedbug_revision_view_page.php?rev_id=1503#r1503
2016-02-05 09:28Patrick BrockmannSteps to Reproduce Updatedbug_revision_view_page.php?rev_id=1505#r1505
2016-08-12 10:00Kitware RobotNote Added: 0038991
2016-08-12 10:00Kitware RobotStatusbacklog => closed
2016-08-12 10:00Kitware RobotResolutionopen => moved
2016-08-12 10:00Kitware RobotAssigned To => Kitware Robot
Notes
(0038991)
Kitware Robot
2016-08-12 10:00
Resolving issue as `moved`.
