MantisBT - ParaView | |||||
View Issue Details | |||||
0015939 | ParaView | (No Category) | public | 2016-01-18 23:17 | 2016-08-24 08:25 |
Reporter | Junjie Xue | ||||
Assigned To | Sebastien Jourdain | ||||
Priority | low | Severity | minor | Reproducibility | have not tried |
Product Version | 4.4 | ||||
Project | Kitware | ||||
Topic Name | |||||
Summary | 0015939: Incorrect shading results in ParaViewWeb Local(VGL) mode | ||||
Description | It seems the Local(VGL) rendering mode in ParaViewWeb has issues with some model files. How to reproduce the issue: open the visualiser, selecte the data file: 'can.ext2'. Under 'Remote mode': all is ok, no issue Under 'Local(VGL) mode': if the model is zoomed out to a certain distance, some faces on the model is shaded black. Under 'Local(VGL) mode': the black area now display as transparency, looks like holes on the model. Figures and data files are attached.you will need to modify the 'far' value in the frustum parameters to '100000.0' display the model. I guees this is caused by the rendering mechanism differences between Paraview and ParaViewWeb . This issue exists in both paraview4.3 & 4.4, anyone knows how to solve it? or any other solutions the get correct rendering results in Local(VGL) mode? Thanks in advance! | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | Model_Plane_1452079291489.tar.gz (2,194,546) 2016-01-18 23:17 https://www.vtk.org/Bug/file/10000/Model_Plane_1452079291489.tar.gz | ||||
Issue History | |||||
2016-01-18 23:17 | Junjie Xue | New Issue | |||
2016-01-18 23:17 | Junjie Xue | Assigned To | => Sebastien Jourdain | ||
2016-01-18 23:17 | Junjie Xue | File Added: Model_Plane_1452079291489.tar.gz | |||
2016-01-19 00:13 | Sebastien Jourdain | Priority | high => low | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038975 | |||
2016-08-24 08:25 | Kitware Robot | View Status | private => public |
Notes | |||||
