MantisBT - ParaView | |||||
View Issue Details | |||||
0015925 | ParaView | (No Category) | public | 2016-01-11 11:47 | 2016-08-12 09:59 |
Reporter | Dan Ibanez | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Product Version | 5.0 | ||||
Project | TBD | ||||
Topic Name | |||||
Type | crash | ||||
Summary | 0015925: can't parse valid Float64 ASCII values | ||||
Description | Using Paraview 5.0.0-RC3 binary distribution for Mac, but also reproduced on Linux with older Paraview versions. The VTK UnstructuredGrid XML Parser fails to read ASCII DataArrays containing values like this: -8.89836e-313 Even when we explicitly state type="Float64". The current workaround is to cast our "double" values to "float" before output. A stand-alone C++ program using "std::cin >> float" accepts these values just fine. Actually, this may have more to do with that value being a sub-normal double precision value. I've confirmed that Paraview accepts the file if the values are changed to this: -8.89836e-300 Which is just above the sub-normal cutoff. An example UnstructuredGrid file is attached. | ||||
Steps To Reproduce | Open the attached file with Paraview. | ||||
Relationships | |||||
Attached Files | bug.vtu (1,037) 2016-01-11 11:47 https://www.vtk.org/Bug/file/9993/bug.vtu | ||||
Issue History | |||||
2016-01-11 11:47 | Dan Ibanez | New Issue | |||
2016-01-11 11:47 | Dan Ibanez | File Added: bug.vtu | |||
2016-01-11 11:59 | Dan Ibanez | Description Updated | bug_revision_view_page.php?rev_id=1452#r1452 | ||
2016-01-11 11:59 | Dan Ibanez | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1454#r1454 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038969 | |||
Notes | |||||
