MantisBT - ParaView | |||||
View Issue Details | |||||
0015878 | ParaView | (No Category) | public | 2015-12-13 18:04 | 2016-08-12 09:59 |
Reporter | Nico Schlömer | ||||
Product Version | |||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015878: Xdmf2Reader: Unknown Attribute Type None, number of components wrong | ||||
Description | I've noticed some oddities with the vtkXdmfReader. The following script ``` import vtk reader = vtk.vtkXdmfReader() reader.SetFileName('test.xmf') reader.Update() grid = reader.GetOutputDataObject(0) point_data = grid.GetPointData() for k in range(point_data.GetNumberOfArrays()): array = point_data.GetArray(k) print(array) ``` produces ``` XDMF Error in /build/vtk6-01UJ_h/vtk6-7.1.0~20151212165543/ThirdParty/xdmf2/vtkxdmf2/libsrc/XdmfAttribute.cxx line 183 (Unknown Attribute Type None) ``` on `GetPointData()`. This is with a simple test file, attached. The supposed "Error" doesn't stop the execution though. However, for the point data, one gets ``` NumberOfComponents: 1 ``` while it is actually 2 (as can be seen by inspecting the file). | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | test.xmf (883) 2015-12-13 18:04 https://www.vtk.org/Bug/file/9980/test.xmf | ||||
Issue History | |||||
2015-12-13 18:04 | Nico Schlömer | New Issue | |||
2015-12-13 18:04 | Nico Schlömer | File Added: test.xmf | |||
2015-12-13 18:07 | Nico Schlömer | Description Updated | bug_revision_view_page.php?rev_id=1428#r1428 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038951 | |||
Notes | |||||
