MantisBT - ParaView
View Issue Details
0015767ParaView(No Category)public2015-10-09 15:082016-07-25 21:57
Alan Scott
T.J. Corona
normalminorhave not tried
closedfixed
4.4
5.1
Sandia
incorrect functionality
0015767: Time display is insane
The time display has gone from bad to absolutely insane. Try ParaView 4.4.0, Linux with can.exo. Step one timestep forward to timestep 1. It shows as 0.00010007373930420727 units (Seconds?). This needs to be fixed.
Please add the ability in the Settings to change this format. Please make the default be the same as Sources/ Annotate Time, which I believe is %f.
No tags attached.
Issue History
2015-10-09 15:08Alan ScottNew Issue
2015-10-09 15:09Alan ScottTarget Version => 5.1
2015-10-15 17:26Alan ScottNote Added: 0035300
2015-11-30 17:49Alan ScottNote Added: 0035490
2015-11-30 17:49Alan ScottTarget Version5.1 => 5.0
2015-12-09 07:41Utkarsh AyachitNote Added: 0035522
2016-01-05 18:18Alan ScottNote Added: 0035632
2016-01-05 18:18Alan ScottNote Edited: 0035632bug_revision_view_page.php?bugnote_id=35632#r1442
2016-01-05 18:19Alan ScottTarget Version5.0 => 5.1
2016-07-12 16:55T.J. CoronaNote Added: 0036347
2016-07-12 16:55T.J. CoronaAssigned To => T.J. Corona
2016-07-12 16:55T.J. CoronaStatusbacklog => customer review
2016-07-12 16:55T.J. CoronaResolutionopen => fixed
2016-07-25 21:16Alan ScottNote Added: 0036578
2016-07-25 21:42Utkarsh AyachitNote Added: 0036581
2016-07-25 21:57Alan ScottNote Added: 0036584
2016-07-25 21:57Alan ScottStatuscustomer review => closed
Notes
(0035300)
Alan Scott
2015-10-15 17:26
Note - Please leave the full precision for time-steps in the Information tab.
(0035490)
Alan Scott
2015-11-30 17:49
Changing to 5.0. Reason is that the display does not show the time exponent, thus a user can't see what time they have if it is small. Impacting one of my users. If this isn't a small fix, OK to slip to PV 5.1
(0035522)
Utkarsh Ayachit
2015-12-09 07:41
Alan,
I don't follow, you want full precision on the Information Tab, but not-full precision (%f) on the Time toolbar? Won't that be misleading?
(0035632)
Alan Scott
2016-01-05 18:18
I don't think so. If Annotate Time isn't misleading, then ditto the time on the time toolbar. Further, we are allowing a user to change it. But, we should have the full, painful, reduculous number somewhere - i.e., the information tab.
I'm moving this to 5.1. 5.0 is done. We missed that train.
(0036347)
T.J. Corona
2016-07-12 16:55
This issue is fixed by the following commit: https://gitlab.kitware.com/paraview/paraview/commit/4d0105fc90d45e5662d7884c78b78878e27652ed [^]
(0036578)
Alan Scott
2016-07-25 21:16
Tested, didn't look like it was checked in.
(0036581)
Utkarsh Ayachit
2016-07-25 21:42
Alan, see this: https://blog.kitware.com/change-the-animation-clock-precision-in-paraview/ [^]
Is it not working. Works for me with `v5.1.0-146-gc3dbc57`. Note, the default hasn't changed. You have to use the setting.
(0036584)
Alan Scott
2016-07-25 21:57
Found it. Closing bug.
Tested master, Linux, local server.
