MantisBT - ParaView | |||||
View Issue Details | |||||
0015757 | ParaView | (No Category) | public | 2015-10-05 17:23 | 2016-08-12 09:59 |
Reporter | Alan Scott | ||||
Product Version | 4.4 | ||||
Target Version | 5.1 | Fixed in Version | |||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0015757: Color palette weirdnesses | ||||
Description | We are seeing color palette weirdness's. This needs to be fixed. * Start by deleting your config files. * ParaView 4.4.0, Linux, local server. <<Bug 1>> * Color Palette icon. Change to gradient background. * Edit current palette. * Change background color to white. OK, OK. All is fine. * Color Palette icon. Change to black background. * Color Palette icon. Change to gradient background. >>>> The white color was not remembered. This is a bug. * Exit ParaView, restart ParaView. * The gradient background now looks as it should, dark blue top, white bottom. Once again, delete your config files. <<Bug 2>> * Properties tab, change Background to Gradient. * On the Color palette icon, change to white background. >>>> We are still in Gradient mode. This is a bug. >>>> Bottom color correctly changes to white, top color stays dark blue. This is a bug. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-10-05 17:23 | Alan Scott | New Issue | |||
2015-10-05 17:23 | Alan Scott | Target Version | => 5.1 | ||
2015-10-26 13:12 | Utkarsh Ayachit | Target Version | 5.1 => 5.0 | ||
2015-10-26 13:33 | Utkarsh Ayachit | Note Added: 0035390 | |||
2015-10-26 13:33 | Utkarsh Ayachit | Target Version | 5.0 => 5.1 | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038903 | |||
Notes | |||||
