MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0015748 | ParaView | (No Category) | public | 2015-09-29 18:57 | 2016-08-12 09:59 |
| Reporter | Kai | ||||
| Assigned To | Kitware Robot | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 4.4 | ||||
| Target Version | Fixed in Version | ||||
| Project | Kitware | ||||
| Topic Name | |||||
| Type | crash | ||||
| Summary | 0015748: ParaViewWeb - Surface with edges issue in ParaViewWeb when doing local rendering | ||||
| Description | The following is the steps to produce the issue: 1. Change to WebGL Rendering Mode - Local Deprecated 2. Load the attached VTK File 3. Color Management- Representation: Surface with Edges Color: T Client side error message WebSocket connection to 'ws://XXXXXXXXXXX:8080/proxy?sessionId=0c562ad6-623f-11e5-9b44-00155dd73e0d' failed: Error during WebSocket handshake: Unexpected response code: 503 Server side Log file 2015-09-23 17:33:52-0400 [-] Log opened. 2015-09-23 17:33:53-0400 [-] Site starting on 9009 2015-09-23 17:33:53-0400 [-] Starting factory <twisted.web.server.Site instance at 0x7fb6f2e55830> 2015-09-23 17:33:53-0400 [HTTPChannel,0,127.0.0.1] Client has reconnected, cancelling reaper 2015-09-23 17:33:53-0400 [HTTPChannel,0,127.0.0.1] on_connect: connection count = 1 pvpython: /home/user/ParaViewWeb/ParaView/src/VTK/Common/Core/vtkDataArrayTemplate.h:191: T vtkDataArrayTemplate<T>::GetValue(vtkIdType) [with T = float; vtkIdType = long long int]: Assertion `id >= 0 && id < this->Size' failed. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/9920/cube.vtk | ||||
| Issue History | |||||
| 2015-09-29 18:57 | Kai | New Issue | |||
| 2015-09-29 18:57 | Kai | File Added: cube.vtk | |||
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038899 | |||
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved | ||
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot | ||
| Notes | |||||
