MantisBT - ParaView
View Issue Details
0015739ParaView(No Category)public2015-09-23 11:372016-08-12 09:59
Ken Moreland
Kitware Robot
normalminorhave not tried
closedmoved
4.4
Sandia
incorrect functionality
0015739: X-, Y-, Z-axis rotation lock does not work with multi-rotation tool
Introduced with ParaView 4.4, you can hold down the x, y, or z button while dragging to lock the camera rotation around the respective axis of the data. This works fine with the default "Rotate" camera manipulator, but does not work with the "Multi-Rotate" camera manipulator. I often replace the rotate tool with the multi-rotate tool when the right mouse button is not as accessible as the left.
No tags attached.
Issue History
2015-09-23 11:37Ken MorelandNew Issue
2015-09-23 12:28Ken MorelandProjectTBD => Sandia
2015-09-23 12:34Utkarsh AyachitNote Added: 0035240
2015-09-23 12:38Ken MorelandNote Added: 0035241
2016-08-12 09:59Kitware RobotNote Added: 0038897
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
2016-08-12 09:59Kitware RobotAssigned To => Kitware Robot
Notes
(0035240)
Utkarsh Ayachit
2015-09-23 12:34
I am going to learn something new today -- I have no idea what Multi-Rotate is :).
(0035241)
Ken Moreland
2015-09-23 12:38
Multi-rotate is a cool variation of the rotate camera interaction. To enable it, go to Settings -> Camera and select it as one of the 3D manipulators. I usually replace Rotate with Multi-Rotate.
With multi-rotate, if you click and drag near the center of the view, it will behave exactly like rotate. If you click and drag near the corners, it will behave like a roll. That way you can get all three degrees of rotation with one button. That's why it's so nice to use on Macs that have only one mouse button.
I think when you hold down x, y, or z, it should rotate the same way that the rotate interaction does now.
(0038897)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
