MantisBT - ParaView | |||||
View Issue Details | |||||
0015631 | ParaView | (No Category) | public | 2015-08-10 15:09 | 2016-08-12 09:59 |
Reporter | Cory Quammen | ||||
Product Version | git-master | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015631: Python annotation filter with representation property inheritance enabled causes error messages | ||||
Description | To reproduce: - Run ParaView, builtin server - Edit -> Settings... General tab, enable Inherit Representation Properties - Load can.ex2 - Add Python Annotation filter. Click apply. You will get an error message like the following: ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0xd0d460): Object type: vtkTextRepresentation, could not find requested method: "SetPosition" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkTextRepresentation (0x4764460)} Argument 1 = string_value {SetPosition} Argument 2 = float64_value {0} Argument 3 = float64_value {0} Argument 4 = float64_value {0} ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 391 vtkPVSessionCore (0xd0d460): Aborting execution for debugging purposes. ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 134 vtkSIProxy (0x47d2910): Error pushing property state: Position ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0xd0d460): Object type: vtkTextProperty, could not find requested method: "SetOrientation" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkTextProperty (0x4293f00)} Argument 1 = string_value {SetOrientation} Argument 2 = float64_value {0} Argument 3 = float64_value {0} Argument 4 = float64_value {0} ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 391 vtkPVSessionCore (0xd0d460): Aborting execution for debugging purposes. ERROR: In /home/cory/code/src/ParaView-review/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 134 vtkSIProxy (0x47e5620): Error pushing property state: Orientation | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-08-10 15:09 | Cory Quammen | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038859 | |||
Notes | |||||
