MantisBT - ParaView | |||||
View Issue Details | |||||
0015488 | ParaView | (No Category) | public | 2015-05-26 05:56 | 2016-08-12 09:59 |
Reporter | Casper van Leeuwen | ||||
Priority | normal | Severity | major | Reproducibility | have not tried |
Product Version | 4.3 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015488: Slice representation large dataset only shows half of the data | ||||
Description | Hello paraview devs, When I try to visualize a large dataset of ~17gb with the slice representation with 4 processes on two cluster nodes (2x GTX780ti 3gb, 2x Intel Xeon CPU E5-2620 v2, 32gb ram per node) with paraview remote I only see half of the image and paraview gives me the following errors: ERROR: In /sara/sw/build/compiles/ParaView-v4.3.1-source/VTK/Imaging/Core/vtkExtractVOI.cxx, line 212 vtkExtractVOI (0x30aa4b0): Error initializing index map. ERROR: In /sara/sw/build/compiles/ParaView-v4.3.1-source/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkCompositeDataPipeline (0x334e200): Algorithm vtkExtractVOI(0x30aa4b0) returned failure for request: vtkInformation (0x3395d80) Debug: Off Modified Time: 1136070 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 If you need additional information let me know. Edit: I found out that it renders the slices only from one process (hence the half slice because of 4 chunks of data one for each process), because I also tested it on a greater number of process/nodes and this would result in an even smaller part of the slice visible. I also tested some filters on the data and these seem to be working as intended, so it has nothing to do with the data distribution among the processes. | ||||
Steps To Reproduce | The dataset is the woodbranch dataset from this site http://www.ifi.uzh.ch/vmml/research/datasets.html. [^] So the procedure to reproduce is very simple. 1. Start a pvserver on an arbitrary number of nodes above 4. 2. Load the above mention dataset in paraview. 3. Set representation on slice. | ||||
Relationships | |||||
Attached Files | paraviewbug.png (602,553) 2015-05-26 05:56 https://www.vtk.org/Bug/file/9802/paraviewbug.png | ||||
Issue History | |||||
2015-05-26 05:56 | Casper van Leeuwen | New Issue | |||
2015-05-26 05:56 | Casper van Leeuwen | File Added: paraviewbug.png | |||
2015-05-26 09:04 | Casper van Leeuwen | Description Updated | bug_revision_view_page.php?rev_id=1096#r1096 | ||
2015-05-26 09:04 | Casper van Leeuwen | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1098#r1098 | ||
2015-05-26 10:31 | Casper van Leeuwen | Severity | minor => major | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038825 | |||
Notes | |||||
