MantisBT - ParaView | |||||
View Issue Details | |||||
0015466 | ParaView | (No Category) | public | 2015-05-12 08:56 | 2016-08-12 09:59 |
Reporter | Felipe Bordeu | ||||
Priority | low | Severity | minor | Reproducibility | have not tried |
Product Version | 4.3 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015466: using PARAVIEW_EXTERNAL_PLUGIN_DIRS with more than one plugin | ||||
Description | When doing the configuration to compile paraview (ccmake) careful must me taken using the PARAVIEW_EXTERNAL_PLUGIN_DIRS variable. If more than one external plugin source directory is added (separated by ;) no trailing / (slash) is permitted. This is because the script that treat this variable (CMake/ParaViewPluginsMacros.cmake:169) create a build directory for each external plugin using the get_filename_component command. If a trailing / is present then the dir_name variable is empty and the plugin is build inside the ExternalPlugin (not in a subdirectory). Cmake gives an error if we use the same build directory to build 2 sources. example using PARAVIEW_EXTERNAL_PLUGIN_DIRS /Path/to/my/plugin1/;/Path/to/my/plugin2/ : CMake Error at CMake/ParaViewPluginsMacros.cmake:187 (add_subdirectory): The binary directory /build/directory/of/ParaView4_binDebug/ExternalPlugins is already used to build a source directory. It cannot be used to build source directory /Path/to/my/plugin2 Specify a unique binary directory name. Call Stack (most recent call first): CMakeLists.txt:727 (pv_process_plugins) using no trailing / solved the problem PARAVIEW_EXTERNAL_PLUGIN_DIRS /Path/to/my/plugin1;/Path/to/my/plugin2 | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-05-12 08:56 | Felipe Bordeu | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038821 | |||
Notes | |||||
