MantisBT - ParaView |
| View Issue Details |
| 0015437 | ParaView | (No Category) | public | 2015-04-29 10:39 | 2015-09-06 12:17 |
| Reporter | Mathieu Westphal | |
| Assigned To | Utkarsh Ayachit | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | 4.3 | |
| Target Version | | Fixed in Version | 4.4 | |
| Project | TBD |
| Topic Name | |
| Type | incorrect functionality |
| Summary | 0015437: Multipiece dataset selection tools select data on the first piece only |
| Description | When working with a multipiece dataset, selecting cells or point in the dataset through the renderview bouton interface will result in a selection in the first block.
"Select Cells on", "Select points on", "Select cells with polygon", "Select point with polygon", "Select block" have this issue.
Only "Select Cells/Points through" works as expected.
| Steps To Reproduce | Open the attached file in ParaView master - it is a multipiece dataset. Select some cells or points. |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | related to | 0015377 | closed | Utkarsh Ayachit | Surface selection broken for AMR datasets |
| Attached Files | bugMultiPiece.tgz (1,686,797) 2015-04-29 10:39 https://www.vtk.org/Bug/file/36/bugMultiPiece.tgz |
| Issue History |
| 2015-04-29 10:39 | Mathieu Westphal | New Issue | |
| 2015-04-29 10:39 | Mathieu Westphal | File Added: bugMultiPiece.tgz | |
| 2015-05-12 03:52 | Joachim Pouderoux | Summary | Multipiece dataset selection systemically select data from first block => Multipiece dataset selection systemically selects data from first piece |
| 2015-05-12 03:52 | Joachim Pouderoux | Description Updated | bug_revision_view_page.php?rev_id=1086#r1086 |
| 2015-05-12 03:52 | Joachim Pouderoux | Steps to Reproduce Updated | bug_revision_view_page.php?rev_id=1088#r1088 |
| 2015-05-12 03:53 | Joachim Pouderoux | Summary | Multipiece dataset selection systemically selects data from first piece => Multipiece dataset selection tools select data on the first piece only |
| 2015-05-13 09:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-06-03 10:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-06-03 10:59 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-06-03 10:59 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-06-03 11:00 | Utkarsh Ayachit | Note Added: 0034454 | |
| 2015-06-04 22:25 | Utkarsh Ayachit | Note Added: 0034510 | |
| 2015-06-04 22:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-06-22 09:13 | Utkarsh Ayachit | Relationship added | related to 0015377 |
| 2015-07-10 21:53 | Alan Scott | Note Added: 0034762 | |
| 2015-07-10 21:53 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
