MantisBT - ParaView | |||||
View Issue Details | |||||
0015348 | ParaView | (No Category) | public | 2015-02-27 08:25 | 2016-08-12 09:59 |
Reporter | xgarnaud | ||||
Product Version | 4.3 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0015348: error with the CGNSReader plugin | ||||
Description | I try to use Paraview 4.3 with the CGNSReader plugin The build process ends without error, the plugin loads but only the geometry is correctly loaded from the files. With the following changes < if (strcmp(location.c_str(), "Vertex") == 0) --- > if (location == "Vertex") 441c440 < else if (strcmp(location.c_str(), "CellCenter") == 0) --- > else if (location == "CellCenter") in Plugins/CGNSReader/cgio_helpers.cxx, and everything works fine. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2015-02-27 08:25 | xgarnaud | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038782 | |||
Notes | |||||
