MantisBT - VTK
View Issue Details
0015279VTK(No Category)public2015-01-25 16:312016-08-12 09:55
Mike Landis
Ben Boeckel (Kitware)
normalminorhave not tried
closedmoved
6.1.0
6.3.0
TBD
crash
0015279: missing libvtkCommonCoreTCL-6.1.so on FedoraCore21
on FedoraCore21.i686 running the simple cone example (code attached)
couldn't load file "/usr/share/libvtkCommonCoreTCL-6.1.so": /usr/share/libvtkCommonCoreTCL-6.1.so: cannot open shared object file: No such file or directory
attempt to provide package vtkCommonCoreTCL 6.1 failed: no version of package vtkCommonCoreTCL provided
attempt to provide package vtkcommoncore 6.1 failed: no version of package vtkcommoncore provided
Error in startup script: attempt to provide package vtk 6.1 failed: no version of package vtk provided
    ("package ifneeded vtk 6.1" script)
    invoked from within
"package.orig require vtk"
    ("eval" body line 1)
    invoked from within
"eval package.orig $args"
    (procedure "package" line 2)
    invoked from within
"package require vtk"
    (file "vtkConeEx.tcl" line 1)
appears to be same as Debian bug #773424 <https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=773424> [^]
Packages vtk-6.1.0-18.fc21.i686 and 1:tcl-8.6.3-1.fc21.i686 installed, but no libvtkCommonCoreTCL-6.1.so found in any directory
No tags attached.
? vtkConeEx.tcl (164) 2015-01-25 16:31
https://www.vtk.org/Bug/file/6/vtkConeEx.tcl
Issue History
2015-01-25 16:31Mike LandisNew Issue
2015-01-25 16:31Mike LandisFile Added: vtkConeEx.tcl
2015-01-25 16:35Mike LandisNote Added: 0034108
2015-02-03 17:46Orion PoplawskiNote Added: 0034145
2015-02-03 17:50Orion PoplawskiNote Added: 0034146
2015-02-03 17:55Orion PoplawskiNote Added: 0034147
2015-02-03 18:21Orion PoplawskiNote Added: 0034149
2015-02-03 19:06Orion PoplawskiNote Added: 0034151
2015-02-03 23:55Orion PoplawskiNote Added: 0034152
2015-02-05 11:46Dave DeMarleAssigned To => Ben Boeckel (Kitware)
2015-02-05 11:52Dave DeMarleNote Added: 0034158
2015-02-05 12:23Orion PoplawskiNote Added: 0034166
2015-02-07 20:16Dave DeMarleNote Added: 0034189
2015-02-07 20:18Dave DeMarleProduct Version => 6.1.0
2015-02-07 20:18Dave DeMarleTarget Version => 6.3.0
2016-08-12 09:55Kitware RobotNote Added: 0037362
2016-08-12 09:55Kitware RobotStatusbacklog => closed
2016-08-12 09:55Kitware RobotResolutionopen => moved
Notes
(0034108)
Mike Landis
2015-01-25 16:35
vtk-tcl-6.1.0-18.fc21.i686 also installed
(0034145)
Orion Poplawski
2015-02-03 17:46
Debian appears to have moved all of the *TCL* libraries into /usr/lib and dropped the soname suffix (e.g. .so.1 -> .so).
The Fedora build uses:
 -DVTK_CUSTOM_LIBRARY_SUFFIX="" \
 -DVTK_INSTALL_LIBRARY_DIR:PATH=%{_lib}/vtk \
 -DVTK_INSTALL_TCL_DIR:PATH=share/tcl%{tcl_version}/vtk \
We get:
/usr/lib64/vtk/libvtkCommonCoreTCL.so.1
Looks like vtk's tcl loader assumes too much:
    ::vtk::init::load_library_package {vtk${kit}TCL} {[file dirname [file dirname [file dirname [info script]]]]}
    proc load_library_package {libName libPath {libPrefix {lib}}} {
      #first try to load a static package, then try the shared package.
      if {[catch "load {} $libName"]} {
        set libExt [info sharedlibextension]
        set currentDirectory [pwd]
        set libFile [file join $libPath "$libPrefix$libName-6.1$libExt"]
        if {[catch "cd {$libPath}; load {$libFile}" errorMessage]} {
          puts $errorMessage
        cd $currentDirectory
Needs to know the directory the libraries are in, and needs take into account library suffix or not.
(0034146)
Orion Poplawski
2015-02-03 17:50
if(DEFINED VTK_CUSTOM_LIBRARY_SUFFIX)
    set(_lib_suffix "${VTK_CUSTOM_LIBRARY_SUFFIX}")
  else()
    set(_lib_suffix "-${VTK_MAJOR_VERSION}.${VTK_MINOR_VERSION}")
  endif()
  set_property(TARGET ${_name} PROPERTY OUTPUT_NAME ${_vtk}${_name}${_lib_suffix})
this _lib_suffix needs to get propagated to:
Wrapping/Tcl/pkgIndex.tcl.in:
        set libFile [file join $libPath "$libPrefix$libName-@VTK_MAJOR_VERSION@.@VTK_MINOR_VERSION@$libExt"]
(0034147)
Orion Poplawski
2015-02-03 17:55
It seems like in Wrapping/Tcl/CMakeLists.txt VTK_TCL_LIBRARY_DIR gets set in two places:
if(VTK_TCL_CONFIGURATION_TYPES)
  foreach(config ${VTK_TCL_CONFIGURATION_TYPES})
    set(VTK_TCL_LIBRARY_DIR "${CMAKE_LIBRARY_OUTPUT_DIRECTORY}/${config}")
    configure_file(${VTK_SOURCE_DIR}/Wrapping/Tcl/pkgIndex.tcl.in
                   ${VTK_BINARY_DIR}/Wrapping/Tcl/${config}/pkgIndex.tcl
                   @ONLY)
  endforeach()
else()
  set(VTK_TCL_LIBRARY_DIR "${CMAKE_LIBRARY_OUTPUT_DIRECTORY}")
                 ${VTK_BINARY_DIR}/Wrapping/Tcl/pkgIndex.tcl
                 @ONLY)
endif()
and then later:
IF(UNIX)
  SET(VTK_TCL_LIBRARY_DIR "[file dirname [file dirname [file dirname [info script]]]]")
ELSE(UNIX)
      "[file join [file dirname [file dirname [file dirname [file dirname [info script]]]]] bin]")
(0034149)
Orion Poplawski
2015-02-03 18:21
Other probable locations needing fixing:
VTK.git/Wrapping/Tcl/vtkbase/vtkbase.tcl.in: set libname [file join $dir ${prefix}${name}-@VTK_MAJOR_VERSION@.@VTK_MINOR_VERSION@${ext}]
VTK.git/CMake/vtkModuleMacros.cmake: set(_lib_suffix "-${VTK_MAJOR_VERSION}.${VTK_MINOR_VERSION}")
VTK.git/ThirdParty/hdf5/vtkhdf5/config/cmake/HDFMacros.cmake: set(_lib_suffix "-${VTK_MAJOR_VERSION}.${VTK_MINOR_VERSION}")
(0034151)
Orion Poplawski
2015-02-03 19:06
This should fix the library path issue:
--- VTK-6.1.0/Wrapping/Tcl/CMakeLists.txt.tcllib 2014-01-22 08:55:41.000000000 -0700
+++ VTK-6.1.0/Wrapping/Tcl/CMakeLists.txt 2015-02-03 16:12:42.635456315 -0700
@@ -261,7 +261,7 @@ endforeach()
 # Configure the Tcl package index file for the install tree.
 SET(VTK_TCL_SCRIPT_DIR "[file dirname [info script]]")
 IF(UNIX)
- SET(VTK_TCL_LIBRARY_DIR "[file dirname [file dirname [file dirname [info script]]]]")
+ SET(VTK_TCL_LIBRARY_DIR "${CMAKE_INSTALL_PREFIX}/${VTK_INSTALL_LIBRARY_DIR}")
 ELSE(UNIX)
For the Fedora build I've just hacked off the suffix in the tcl.in files. A proper fix would propagate a VTK_LIBRARY_SUFFIX variable.
(0034152)
Orion Poplawski
2015-02-03 23:55
Mike - try https://admin.fedoraproject.org/updates/vtk-6.1.0-23.fc21 [^]
(0034158)
Dave DeMarle
2015-02-05 11:52
@Orion - is the patch complete?
@ Ben, is this patch:
* in the set you scooped up for inclusion in vtk master?
* unlikely to break anything? - if so let's hold off merging until the imminent 6.2 release is over
(0034166)
Orion Poplawski
2015-02-05 12:23
No the patch only addresses the library location issue, but not the library suffix issue. I've got a Fedora specific patch in place, so I'm happy for now.
(0034189)
Dave DeMarle
2015-02-07 20:16
Thanks, ping us after the 6.2 release please and if we need the big guns, we'll get Dave Gobbi's attention. :)
(0037362)
Kitware Robot
2016-08-12 09:55
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
