MantisBT - ParaView | |||||
View Issue Details | |||||
0015147 | ParaView | (No Category) | public | 2014-11-22 07:58 | 2016-08-12 09:59 |
Reporter | Joachim Pouderoux | ||||
Assigned To | Joachim Pouderoux | ||||
Product Version | git-next | ||||
Project | ParaViS | ||||
Topic Name | |||||
Type | feature | ||||
Summary | 0015147: Imp: In the bar chart, display the ticks limiting each bar by default | ||||
Description | When calling the filter histogram, a bar chart view is created with rounded values in the X-axis. In order to know a bar correspond to which interval, the X-axis must have values corresponding to the interval of computation of each bar. This can be obtained via: - View properties - Bottom axis layout - Specify axis labels explicitly - Generate: - From: min value of the field - To: max value of the field - Steps: number of bars + 1 This should be the default behaviour so as to understand what each bar means. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2014-11-22 07:58 | Joachim Pouderoux | New Issue | |||
2014-11-22 07:58 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux | ||
2014-11-22 07:58 | Joachim Pouderoux | Status | backlog => active development | ||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038719 | |||
2016-08-12 09:59 | Kitware Robot | Status | active development => closed | ||
Notes | |||||
