MantisBT - ParaView
View Issue Details
0014996ParaView(No Category)public2014-09-15 16:562016-08-12 09:59
Andy Bauer
Utkarsh Ayachit
normalminorhave not tried
closedmoved
git-master
TBD
incorrect functionality
0014996: Ensight reader has problems with 14 processes
When trying to read in an Ensight file with 14 processes (doesn't seem to cause problems with less processes) I get the following error:
ERROR: In /home/acbauer/CODE/ParaView/ParaView-v4.1.0/VTK/Common/DataModel/vtkDataSet.cxx, line 414
vtkStructuredGrid (0xa70560): Point array DENS with 1 components, only has -325 tuples but there are 0 points
Steps to reproduce:
1) start pvserver with 14 processes
2) connect the client
3) load the naca.bin.case file in ParaViewData in Data/Ensight
This was on an ubuntu 12.04 machine with GCC 4.6.4 and OpenMPI 1.4.3.
No tags attached.
Issue History
2014-09-15 16:56Andy BauerNew Issue
2014-09-15 16:56Andy BauerAssigned To => Utkarsh Ayachit
2014-09-17 13:13Andy BauerNote Added: 0033366
2016-08-12 09:59Kitware RobotNote Added: 0038656
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
Notes
(0033366)
Andy Bauer
2014-09-17 13:13
Using files that Mike Stephens shared with me, I can reproduce a similar problem. The files are at /home/acbauer/DATA/ERDC/STEPHENS/EnsightIssue-9-16-2014/wing/wpfsFlow.case (they can't be shared outside of Kitware). Steps to reproduce:
1) run pvserver with 14 processes
2) connect a client
3) load the file
4) use the extract block filter to extract any of the "Patch = *" files
There won't be any fields defined over the grid in this case. If the file is loaded into PV with the built-in server then all blocks have fields defined over them.
(0038656)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
