MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0014870 | ParaView | (No Category) | public | 2014-07-16 19:24 | 2016-08-12 09:59 | |||||
Reporter | Alan Scott | |||||||||
Assigned To | Utkarsh Ayachit | |||||||||
Priority | high | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | moved | |||||||
Platform | OS | OS Version | ||||||||
Product Version | git-master | |||||||||
Target Version | 5.1 | Fixed in Version | ||||||||
Project | Sandia | |||||||||
Topic Name | ||||||||||
Type | incorrect functionality | |||||||||
Summary | 0014870: Suppress Ordered Compositing toggle doesn't work | |||||||||
Description | When using multiple servers, with CAM data, ordered compositing toggle isn't working. It should be fixed for 4.2, since this significantly impacts visualizing CAM data. 1) On master, this state setting is missing. Please add it back. On 4.1.0, it was found under Edit/ Settings/ Render View/ Server/ Remote Rendering Parameters/ Suppress Ordered Compositing. 2) On 4.1.0, clicking on this button does nothing. The way to show this is as follows: 4.1.0, remote server (I had 8 of them), Linux. Settings/ RenderView/ Server. Select Suppress Ordered Compositing. I even exited ParaView and logged back on, but I don't believe this is necessary. Open the CAM data from bug 14866. Single Level on, Cell Layer Right off. Fill in the Connectivity File Name as done in 14866. Apply. Change variable to TMQ. Color Editor - Enable opacity mapping for surfaces. Go forward one time step. Tools, Timer log. Notice that Redistributing Data for Ordered Compromising is in the log. This means (as per Utkarsh) that the turning off ordered compositing above didn't work. Please fix this. Note - I corrected this bug, including title, since it was wrong. Alan. | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | WIP.patch (7,292) 2014-07-18 11:59 https://www.vtk.org/Bug/file/9682/WIP.patch | |||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2014-07-16 19:24 | Alan Scott | New Issue | ||||||||
2014-07-16 19:24 | Alan Scott | Relationship added | related to 0014866 | |||||||
2014-07-16 19:25 | Alan Scott | Target Version | => 4.2 | |||||||
2014-07-17 16:01 | Alan Scott | Summary | Depth peeling toggle doesn't work => Supress Ordered Compositing toggle doesn't work | |||||||
2014-07-17 16:01 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=795#r795 | |||||||
2014-07-18 11:59 | Utkarsh Ayachit | File Added: WIP.patch | ||||||||
2014-07-18 12:00 | Utkarsh Ayachit | Note Added: 0033036 | ||||||||
2014-07-18 12:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | |||||||
2014-07-30 16:25 | Alan Scott | Note Added: 0033163 | ||||||||
2014-07-30 16:25 | Alan Scott | Summary | Supress Ordered Compositing toggle doesn't work => Suppress Ordered Compositing toggle doesn't work | |||||||
2014-07-30 16:25 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=801#r801 | |||||||
2014-09-12 14:25 | Alan Scott | Target Version | 4.2 => 4.3 | |||||||
2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.3 => 4.4 | |||||||
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 | |||||||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038602 | ||||||||
2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | |||||||
Notes | |||||
