MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0014828 | ParaView | (No Category) | public | 2014-06-27 19:19 | 2015-01-09 13:42 |
| Reporter | Alan Scott | ||||
| Assigned To | Utkarsh Ayachit | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | ||
| Product Version | git-master | ||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||
| Project | Sandia | ||||
| Topic Name | 14828_fix_scalar_coloring | ||||
| Type | incorrect functionality | ||||
| Summary | 0014828: Contours, color by is crazy broken | ||||
| Description | When you contour, then color by something, ParaView gets very confused. I don't know if this is one bug, or numerous. Should be fixed for 4.2. * Linux, local server, master. * Source/ Wavelet. Apply. * Slice. Turn off Show Plane. Apply. * +X * Hide visibility of Wavelet. * Not necessary, but Reset (X) * Contour, by rtdata, take default, apply. <<Bug - you can't color by rtdata>> (Ah, this is by design, you say!) * Restart ParaView from scratch. * Open disk_out_ref.exo. All vars on. Apply. * Slice. Turn off Show Plane. Apply. * +X * Not necessary, but Reset (X) * Color by temp. * Contour filter. Contour by temp. Change value range to 400. Apply. <<Inconsistancy>> We are now contouring by temp. <<Bug>> If you look at the Color By in the Properties tab, it doesn't show Solid Color (but should). The Color By in the top tool bar does! * Color by "Solid Color". (Top tool bar.) (Contour goes white.) * Color editor. Change color to black. * Color by temp. <<bug>> Contour stays black! You can never color by any var again, until you change the color back to white. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2014-06-27 19:19 | Alan Scott | New Issue | |||
| 2014-06-27 19:26 | Alan Scott | Product Version | => git-master | ||
| 2014-06-27 19:26 | Alan Scott | Description Updated | bug_revision_view_page.php?rev_id=776#r776 | ||
| 2014-06-28 08:17 | Utkarsh Ayachit | Target Version | => 4.2 | ||
| 2014-07-06 15:33 | Cory Quammen | Note Added: 0032972 | |||
| 2014-07-07 11:08 | Cory Quammen | Note Edited: 0032972 | bug_revision_view_page.php?bugnote_id=32972#r785 | ||
| 2014-07-18 15:34 | Utkarsh Ayachit | Note Added: 0033038 | |||
| 2014-07-22 10:38 | Utkarsh Ayachit | Topic Name | => 14828_fix_scalar_coloring | ||
| 2014-07-22 10:38 | Utkarsh Ayachit | Note Added: 0033062 | |||
| 2014-07-22 10:38 | Utkarsh Ayachit | Status | backlog => gatekeeper review | ||
| 2014-07-22 10:38 | Utkarsh Ayachit | Fixed in Version | => git-next | ||
| 2014-07-22 10:38 | Utkarsh Ayachit | Resolution | open => fixed | ||
| 2014-07-22 10:38 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
| 2014-07-23 10:18 | Utkarsh Ayachit | Note Added: 0033071 | |||
| 2014-07-23 10:18 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
| 2014-07-23 10:18 | Utkarsh Ayachit | Fixed in Version | git-next => git-master | ||
| 2014-07-24 20:20 | Alan Scott | Note Added: 0033078 | |||
| 2014-07-24 20:20 | Alan Scott | Status | customer review => closed | ||
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 | ||
| 2015-01-09 13:41 | Utkarsh Ayachit | Source_changeset_attached | => VTK master f0165b18 | ||
| 2015-01-09 13:41 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 53fc29f1 | ||
| 2015-01-09 13:42 | Utkarsh Ayachit | Source_changeset_attached | => VTK master daf8c6e7 | ||
| Notes | |||||
