MantisBT - ParaView | |||||
View Issue Details | |||||
0014738 | ParaView | (No Category) | public | 2014-05-19 08:08 | 2014-08-29 11:00 |
Reporter | Vadim SANDLER | ||||
Assigned To | Joachim Pouderoux | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | ||
Product Version | 4.1 | ||||
Target Version | 4.2 | Fixed in Version | 4.2 | ||
Project | ParaViS | ||||
Topic Name | FixGeometryFilterProxy | ||||
Summary | 0014738: Crash in the vtkPVGeometryFilter on the simple case | ||||
Description | An attached file "carre.vtu" contains 4 quadrangles. Applying of the vtkPVGeometryFilter to this data set leads to the crash of the application. Run attached python script carre.py, in the result application crashes, in the console displayed the following log: paraview version 4.1.0 ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 389 vtkPVSessionCore (0x2b35510): Object type: vtkPVGeometryFilter, could not find requested method: "SetMakeOutlineOfInput" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkPVGeometryFilter (0x61711c0)} Argument 1 = string_value {SetMakeOutlineOfInput} Argument 2 = int32_value {0} ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0x2b35510): Aborting execution for debugging purposes. ############ ABORT ############# ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 486 vtkSISourceProxy (0x6170ff0): Could not parse property: MakeOutlineOfInput ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ClientServerCore/Core/vtkPVAlgorithmPortsInformation.cxx, line 56 vtkPVAlgorithmPortsInformation (0x613c650): Could not downcast vtkAlgorithm. ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 267 vtkSISourceProxy (0x6170ff0): Incorrect message received. Missing xml_group and xml_name information. global_id: 4840 location: 1 [paraview_protobuf.ProxyState.property] { name: "Input" value { type: INPUT proxy_global_id: 4829 port_number: 0 } } Invalid output port : pqPipelineSource::getOutputPort( 0 ). Available number of output ports: 0. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | carre.zip (964) 2014-05-19 08:12 https://www.vtk.org/Bug/file/9654/carre.zip | ||||
Issue History | |||||
2014-05-19 08:08 | Vadim SANDLER | New Issue | |||
2014-05-19 08:12 | Vadim SANDLER | File Added: carre.zip | |||
2014-06-05 10:59 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux | ||
2014-06-05 10:59 | Joachim Pouderoux | Reproducibility | have not tried => always | ||
2014-06-05 11:03 | Joachim Pouderoux | Note Added: 0032750 | |||
2014-06-05 11:08 | Joachim Pouderoux | Note Added: 0032751 | |||
2014-06-05 11:09 | Joachim Pouderoux | Status | backlog => active development | ||
2014-06-05 11:54 | Joachim Pouderoux | Status | active development => gatekeeper review | ||
2014-06-05 11:54 | Joachim Pouderoux | Resolution | open => fixed | ||
2014-06-06 05:00 | Utkarsh Ayachit | Topic Name | => FixGeometryFilterProxy | ||
2014-06-06 05:07 | Utkarsh Ayachit | Fixed in Version | => git-master | ||
2014-06-06 05:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
2014-06-06 05:08 | Utkarsh Ayachit | Note Added: 0032767 | |||
2014-06-10 21:58 | Alan Scott | Note Added: 0032838 | |||
2014-06-10 21:58 | Alan Scott | Status | customer review => closed | ||
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 | ||
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
Notes | |||||
