MantisBT - ParaView | |||||
View Issue Details | |||||
0001461 | ParaView | (No Category) | public | 2005-01-07 13:54 | 2016-08-12 09:57 |
Reporter | Lee Ankeny | ||||
Priority | normal | Severity | minor | Reproducibility | always |
Product Version | |||||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0001461: LA: renderserver and tiled display are incompatible | ||||
Description | Tiled-display works, and client/server/renderserver works, but they don't work together anymore. Below are the three commandlines and the ensuing errors. In this case I'm using a non-parallel build of PV 1.8, but the same problem occurs with MPI and with the CVS trunk. This worked in 1.6, and I thought it worked in 1.8 at one time, but possibly not. ====================================== ib000.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/paraview -rs -m=rshostfile Listen on port: 22221 RenderServer: Waiting for client... connected to port 22221 Client connected. Connect: id :0 host: ib001 Port:11111 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkSocketCommunicator.cxx, line 572 vtkSocketCommunicator (0x98a75b8): Could not receive tag. 315167 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkMultiProcessController.cxx, line 354 vtkSocketController (0x98c4470): Could not receive RMI trigger message. Exit Render Server. ====================================== ib001.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/pvserver -m=dshostfile Listen on port: 11111 Waiting for client... connected to port 11111 Client connected. open with port 11111 WaitForConnection: id :0 Port:11111 Received Hello from process 0 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkSocketCommunicator.cxx, line 572 vtkSocketCommunicator (0x9329610): Could not receive tag. 315167 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkMultiProcessController.cxx, line 354 vtkSocketController (0x9346f08): Could not receive RMI trigger message. Exit Data Server. ====================================== ib028.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/paraview -crs -r2d -rsh=ib000 -h=ib001 -tdx=1 -tdy=1 Connect to ib001:11111 Connect to ib000:22221 Object type: vtkMPIMoveData, could not find requested method: "SetMPIMToNSocketConnection" or the method was called with incorrect arguments. Abort (core dumped) ================================================== dshostfile contains: ib001 rshostfile contains: ib000 | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-12-09 14:51 | Berk Geveci | Project | @3@ => ParaView | ||
2009-12-10 06:52 | Berk Geveci | Status | backlog => tabled | ||
2009-12-10 06:52 | Berk Geveci | Assigned To | Amy Squillacote => Utkarsh Ayachit | ||
2011-06-16 13:09 | Zack Galbreath | Category | => (No Category) | ||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037489 | |||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | ||
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
Notes | |||||
