MantisBT - VTK | |||||
View Issue Details | |||||
0014586 | VTK | (No Category) | public | 2014-02-20 03:44 | 2015-02-09 15:42 |
Reporter | Jorge | ||||
Assigned To | Ben Boeckel (Kitware) | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Status | closed | Resolution | fixed | ||
Product Version | 6.0.0 | ||||
Target Version | Fixed in Version | 6.2.0 | |||
Project | Kitware | ||||
Summary | 0014586: error in vtkLocal with BUILD_SHARED_LIBS=ON | ||||
Description | Hello I have an error when trying to build the example Examples/Build/vtkLocal outside the vtk build tree with BUILD_SHARED_LIBS=ON. My VTK was built with TCL wrapping ON. This bug has being also mentioned at http://stackoverflow.com/questions/19918691/how-do-i-build-the-vtklocal-example-with-shared-libraries-on [^] If I remove the string -lTCL manually from the command line used to build the lib then shared lib is created correctly (I discovered the command line passing VERBOSE=1 to make). I have test it with VTK 6.1.0 and cmake version 2.8.9. Here I attach the CMakeCache.txt and the modified CMakeList.txt with BUILD_SHARED_LIBS=ON | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | CMakeCache.txt (13,789) 2014-02-20 03:45 https://www.vtk.org/Bug/file/9612/CMakeCache.txt CMakeLists.txt (526) 2014-02-20 03:45 https://www.vtk.org/Bug/file/9613/CMakeLists.txt | ||||
Issue History | |||||
2014-02-20 03:44 | Jorge | New Issue | |||
2014-02-20 03:45 | Jorge | File Added: CMakeCache.txt | |||
2014-02-20 03:45 | Jorge | File Added: CMakeLists.txt | |||
2014-05-06 06:17 | Jorge | Note Added: 0032618 | |||
2015-02-05 12:36 | Dave DeMarle | Assigned To | => Ben Boeckel (Kitware) | ||
2015-02-05 12:37 | Dave DeMarle | Note Added: 0034171 | |||
2015-02-07 21:53 | Dave DeMarle | Note Added: 0034191 | |||
2015-02-07 21:53 | Dave DeMarle | Status | backlog => gerrit review | ||
2015-02-09 15:42 | Ben Boeckel (Kitware) | Note Added: 0034197 | |||
2015-02-09 15:42 | Ben Boeckel (Kitware) | Status | gerrit review => closed | ||
2015-02-09 15:42 | Ben Boeckel (Kitware) | Resolution | open => fixed | ||
2015-02-09 15:42 | Ben Boeckel (Kitware) | Fixed in Version | => 6.2.0 |
Notes | |||||
