MantisBT - ParaView
View Issue Details
0014536ParaView(No Category)public2014-01-22 11:542016-08-12 09:59
Dan Lipsa
Kitware Robot
normalminorhave not tried
closedmoved
TBD
incorrect functionality
0014536: Recording a test for setting a background image does not work.
Record a test:
paraview -dr
Tools / Record Test...
Choose the file where to save the test
Set Background type to 'Image'
Choose 'Load...'
In the file dialog choose ParaView/Data/NE2_ps_bath.png
Press 'Stop recording'
Press 'Disconnect'
Play the test:
Tools / Play Test...
Choose the test file you just saved.
You'll get the following error:
Couldn't find object "pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color/0QColorDialog0"
Found up to "pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color"
No tags attached.
Issue History
2014-01-22 11:54Dan LipsaNew Issue
2014-01-29 09:33Dan LipsaNote Added: 0032229
2016-08-12 09:59Kitware RobotNote Added: 0038500
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
2016-08-12 09:59Kitware RobotAssigned To => Kitware Robot
Notes
(0032229)
Dan Lipsa
2014-01-29 09:33
A workaround is to save this event before accessing the dialog.
<pqevent object="pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color" command="activate" arguments="" />
(0038500)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
