MantisBT - ParaView |
| View Issue Details |
| 0014333 | ParaView | (No Category) | public | 2013-10-17 17:24 | 2014-08-29 10:59 |
| Reporter | Alan Scott | |
| Assigned To | Cory Quammen | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | git-master | |
| Target Version | | Fixed in Version | 4.2 | |
| Project | Sandia |
| Topic Name | |
| Type | incorrect functionality |
| Summary | 0014333: Gradient colors don't persist between runs. |
| Description | Gradient color doesn't persist between runs. Further, Gradient color probably shouldn't be on the View Settings dialog box.
* Master, Linux, local server.
* Edit/ View Settings/ General. Click on Gradient Color.
* Change the second color to red. Apply.
* Close ParaView and reopen ParaView.
<Bug> - Gradient color background is not in effect.
<Bug> - If you turn on Gradient Color again, the second color of red is reset.
<Possible bug> - should this functionality be moved to the Settings dialog?
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | related to | 0014521 | closed | Utkarsh Ayachit | Add ability to save default values for all/any properties |
| Attached Files | |
| Issue History |
| 2013-10-17 17:24 | Alan Scott | New Issue | |
| 2013-11-04 11:21 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
| 2013-12-06 23:55 | Cory Quammen | Note Added: 0031909 | |
| 2013-12-06 23:55 | Cory Quammen | Status | backlog => active development |
| 2013-12-07 00:12 | Cory Quammen | Note Edited: 0031909 | bug_revision_view_page.php?bugnote_id=31909#r682 |
| 2013-12-09 18:54 | Alan Scott | Note Added: 0031917 | |
| 2013-12-23 11:25 | Cory Quammen | Note Added: 0032047 | |
| 2014-01-21 09:56 | Utkarsh Ayachit | Relationship added | related to 0014521 |
| 2014-06-27 15:11 | Utkarsh Ayachit | Note Added: 0032950 | |
| 2014-06-27 15:11 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2014-06-27 15:11 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2014-06-27 15:11 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-06-30 08:24 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-06-30 08:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-06-30 08:24 | Utkarsh Ayachit | Note Added: 0032954 | |
| 2014-07-07 21:51 | Alan Scott | Note Added: 0032978 | |
| 2014-07-07 21:51 | Alan Scott | Status | customer review => closed |
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0031909)
Cory Quammen
2013-12-06 23:55
(edited on: 2013-12-07 00:12) |
Hi Alan,
The background color and gradient are properties of the 3D view. You can have several 3D views in a layout, each with a potentially different background. As properties of the view, the colors are not saved as application settings, but they are saved to a state file. If they were application settings, then you wouldn't be able to have different backgrounds in different 3D views.
You can change the default background color for new 3D views in the Settings -> Color panel. Click on Background Color and change it to something. The next time you create a 3D view, it will have the background color you chose. I don't see an option to make a gradient default, nor the second color for the gradient. We could potentially add that setting.
Best,
Cory
(0031917)
Alan Scott
2013-12-09 18:54
Cory,
You are correct - the View Settings setting should not be saved. However, a user should be able to set default backgrounds, using all of the options available in Edit/ View Settings/ General. In other words, for this bug, please make sure that Settings/ Colors (or wherever else it should be) allows a user to set gradient, and gradient colors |
(0032047)
Cory Quammen
2013-12-23 11:25
Alan,
That request seems perfectly reasonable. Defaults settings are inconsistent within ParaView and across the other binaries (pvbatch and pvpython).
This bug fits into a larger project involving refactoring of settings in ParaView. For your reference, here is a link discussing some of the issues and potential solutions:
http://paraview.org/ParaView/index.php/ParaView_Settings_2.0 [^]
The tentative plan is to address this bug while addressing the larger challenge of settings. |
(0032950)
Utkarsh Ayachit
2014-06-27 15:11
This now works:
+ When changing background color on the "Properties" panel, the change only affects the current view.
+ Now to save that change to "user settings" so that it will be used next time ParaView starts up (or creates a new view), hit the "Save current views settings as default" button on the Properties panel next to the "View" (the icon with a disk drive). That should do the trick. |
(0032954)
Utkarsh Ayachit
2014-06-30 08:24
SUMMARY
Topics merged into master:
14557-color-legend-update
(VTK) 14713_fix_lsdyna_reader
14788-pqTextEdit
14814_fix_cell_point_label_format
14827_fix_paraview_module_requirements
misc_quad_view_fixes
(0032978)
Alan Scott
2014-07-07 21:51
Nice.
Tested local server, Linux, master. |
