MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0014235 | ParaView | (No Category) | public | 2013-08-15 12:47 | 2016-08-12 09:59 |
| Reporter | Philip Cardiff | ||||
| Assigned To | Kitware Robot | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 4.0 | ||||
| Target Version | Fixed in Version | ||||
| Project | TBD | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0014235: Cannot load decomposed OpenFOAM model containing globalFaceZones | ||||
| Description | If you try to view a decomposed OpenFOAM model which contains globalFaceZones (for example $FOAM_TUTORIALS/incompressible/icoDyMFoam/mixerGgi), you get a warning about the number of faces in 'faces' and 'owner' not matching. the globalFaceZones add faces to 'face' but they do not have owners, so I imagine it should be fine to ignore these extra faces. The warning/errror is: Warning: In /Users/kitware/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 4725 vtkOpenFOAMReaderPrivate (0x114a3bec0): Numbers of faces in faces 668 and owner 614 does not match ERROR: In /Users/kitware/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkCompositeDataPipeline (0x114a3b2e0): Algorithm vtkOpenFOAMReader(0x114a3ab70) returned failure for request: vtkInformation (0x1149edb30) Debug: Off Modified Time: 120621 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 Best regards, Philip | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2013-08-15 12:47 | Philip Cardiff | New Issue | |||
| 2013-08-15 12:49 | Philip Cardiff | Note Added: 0031465 | |||
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038436 | |||
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved | ||
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot | ||
| Notes | |||||
