MantisBT - ParaView |
View Issue Details |
0014184 | ParaView | (No Category) | public | 2013-07-25 13:03 | 2014-08-29 10:59 |
Reporter | Alejandro Ribes | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | fixed | |
Product Version | 4.0 | |
Target Version | 4.2 | Fixed in Version | 4.2 | |
Project | ParaViS |
Topic Name | refactor_python_tracing_2 |
Type | incorrect functionality |
Summary | 0014184: CSV reader producing invalid Python trace |
Description | Attachments:
sinus.csv - a simple CSV file containing 4 lines of two values (comma
separated)
trace_adr.py - ParaView generated Python trace
Description:
The Python trace generated by ParaView when importing the CSV file given
in attachment can not be re-executed.
Error trace:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File
"/export/home/adrien/my_salome/prereq/ParaView-4.0.1_INSTALL_Debug/lib/paraview-4.0/site-packages/paraview/simple.py",
line 300, in Show
raise RuntimeError, "Could not create a representation object for
proxy %s" % proxy.GetXMLLabel()
RuntimeError: Could not create a representation object for proxy CSV
Reader
Steps to reproduce
- open ParaView
- start Trace
- open the CVS file sinus.csv
- click Apply
- stop trace
- Run pvpython
- execute the lines of code given in the trace
Steps To Reproduce | |
Additional Information | |
Tags | PythonTrace |
Attached Files | test-files.tar.gz (449) 2013-07-25 13:03 https://www.vtk.org/Bug/file/9482/test-files.tar.gz |
2013-07-25 13:03 | Alejandro Ribes | New Issue | |
2013-07-25 13:03 | Alejandro Ribes | Assigned To | => Utkarsh Ayachit |
2013-07-25 13:03 | Alejandro Ribes | File Added: test-files.tar.gz | |
2013-07-25 17:21 | Alan Scott | Note Added: 0031333 | |
2013-07-25 17:21 | Alan Scott | Summary | CVS reader producing invalid Python trace => CSV reader producing invalid Python trace |
2013-07-29 16:43 | Utkarsh Ayachit | Note Added: 0031362 | |
2014-06-19 10:33 | Vadim SANDLER | Note Added: 0032905 | |
2014-06-22 18:19 | Utkarsh Ayachit | Note Added: 0032908 | |
2014-06-22 18:20 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-07-04 19:17 | Utkarsh Ayachit | Tag Attached: PythonTrace | |
2014-07-09 21:53 | Utkarsh Ayachit | Note Added: 0033003 | |
2014-07-18 21:00 | Utkarsh Ayachit | Topic Name | => refactor_python_tracing_2 |
2014-07-18 21:00 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-18 21:00 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-07-18 21:00 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-22 08:32 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-07-22 08:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-22 08:32 | Utkarsh Ayachit | Note Added: 0033055 | |
2014-07-28 18:31 | Alan Scott | Note Added: 0033114 | |
2014-07-28 18:31 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
(0031333)
Alan Scott
2013-07-25 17:21
Correcting title. It is a CSV reader, not a CVS reader. |
(0031362)
Utkarsh Ayachit
2013-07-29 16:43
The problem boils down to missing support for spreadsheet view in Python. |
(0032905)
Vadim SANDLER
2014-06-19 10:33
Utkarsh,
The problem with the script generated via trace functionality is reproduced even in the GUI mode (not in pvpython), there are the steps to reproduce the problem:
- open ParaView
- start Trace
- open the CSV file sinus.csv
- click Apply
- stop trace
- save generated trace in the file
- Menu Tools -> Python Shell
- Run Script, select the created file
File "<string>", line 12, in <module>
File "/dn20/salome/rnv/PRODUCTS_BUILD/prefix/ParaView-4.1.0/lib/paraview-4.1/site-packages/paraview/servermanager.py", line 254, in __setattr__
setter(self, value)
File "/dn20/salome/rnv/PRODUCTS_BUILD/prefix/ParaView-4.1.0/lib/paraview-4.1/site-packages/paraview/servermanager.py", line 2477, in setProperty
return self.SetPropertyWithName(propName, value)
File "/dn20/salome/rnv/PRODUCTS_BUILD/prefix/ParaView-4.1.0/lib/paraview-4.1/site-packages/paraview/servermanager.py", line 309, in SetPropertyWithName
prop.SetData(arg)
File "/dn20/salome/rnv/PRODUCTS_BUILD/prefix/ParaView-4.1.0/lib/paraview-4.1/site-packages/paraview/servermanager.py", line 730, in SetData
self.SMProperty.SetElement(idx, self.ConvertValue(val))
File "/dn20/salome/rnv/PRODUCTS_BUILD/prefix/ParaView-4.1.0/lib/paraview-4.1/site-packages/paraview/servermanager.py", line 885, in ConvertValue
raise ValueError("%s is not a valid value." % value)
ValueError: Row Data is not a valid value.
Regards,
Roman. |
(0032908)
Utkarsh Ayachit
2014-06-22 18:19
Vadim,
FYI, I am working on refactoring the Python tracing framework. I'll make sure this is handled better in this refactor.
Utkarsh |
(0033003)
Utkarsh Ayachit
2014-07-09 21:53
Developer note:
This is what the current trace generate produces
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
paraview.simple._DisableFirstRenderCameraReset()
# create a new 'CSV Reader'
sinuscsv = CSVReader(FileName=['/tmp/sinus.csv'])
# get active view
renderView0 = GetActiveViewOrCreate('RenderView')
# uncomment following to set a specific view size
# renderView0.ViewSize = [1387, 796]
# get layout
viewLayout0 = GetLayout()
# Create a new 'SpreadSheet View'
spreadSheetView0 = CreateView('SpreadSheetView')
# spreadSheetView0.ViewSize = [400, 400]
# place view in the layout
viewLayout0.AssignView(2, spreadSheetView0)
# show data in view
sinuscsvDisplay = Show(sinuscsv, spreadSheetView0)
#### saving camera placements for all active views
# current camera placement for renderView0
#### uncomment the following to render all views
# RenderAllViews()
# alternatively, if you want to write images, you can use SaveScreenshot(...).
(0033055)
Utkarsh Ayachit
2014-07-22 08:32
Topics merged into master:
0014874_fix_scalar_opacity_unit_distance
14834_fix_representation_update
dashboard-warnings-20140721
(0033114)
Alan Scott
2014-07-28 18:31
Tested master, remote server, Linux. |
