MantisBT - ParaView
View Issue Details
0014137ParaView(No Category)public2013-06-20 10:582016-08-12 09:59
grenon
Kitware Robot
normalminorhave not tried
closedmoved
TBD
feature
0014137: Request feature of a "Select blocks through" selection mode
The problem arises when you want to select blocks on a complex geometry with many blocks and when it is not possible to have a point of view showing all searched blocks: the "Select blocks" mode gives only VISIBLE blocks that are inside or intersect the rubberband frame drawn when dragging the mouse.
It would be nice to have a "Select blocks through" that gives ALL blocks inside a Frustum that works like for the cells in the "Select cells through" mode.
No tags attached.
Issue History
2013-06-20 10:58grenonNew Issue
2016-08-12 09:59Kitware RobotNote Added: 0038409
2016-08-12 09:59Kitware RobotStatusbacklog => closed
2016-08-12 09:59Kitware RobotResolutionopen => moved
2016-08-12 09:59Kitware RobotAssigned To => Kitware Robot
Notes
(0038409)
Kitware Robot
2016-08-12 09:59
Resolving issue as `moved`.
