MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0013901 | ParaView | (No Category) | public | 2013-02-19 20:56 | 2014-09-16 17:32 | |||||
| Reporter | Alan Scott | |||||||||
| Assigned To | Utkarsh Ayachit | |||||||||
| Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
| Status | closed | Resolution | no change required | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | 3.98.1 | |||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | |||||||
| Project | Sandia | |||||||||
| Topic Name | ||||||||||
| Type | usability | |||||||||
| Summary | 0013901: Allow 2d plots to remember previous settings (if applicable). | |||||||||
| Description | There are some viz sessions that show a need to have 2d plots remember previous settings, or the ability to copy state from one 2d window to another. For instance, Linux, 3.98.1, local server. * Open particles.h5part. (Dataset is 2d-plot-bug-datasets, ask me for this dataset.) * Turn only type, vx, x, y and z on. Set Xarray to x, Yarray to y, and Zarray to z. Apply. * Threshold filter. Threshold on type, lower and upper bounds == 1. Apply. * Plot Data. Apply. Turn all variables off, then only turn on vx. Change X Zxis Data to "Use Data Array", == x. Highlight the vx variable, set line style to none, marker style to plus. Change color to black. View Options, Specify axis range explicitly, min/max to -1000 and 1000. Apply. * Now, repeat the previous two bullets 2 more times. All three resultant 2d views are as follows: -- threshold type 1, black (this one was created in the paragraph above). -- threshold type 3, blue (color defaults to blue, OK). -- threshold type 2, another color (Color needs changing again). * Now, read in the dataset output.e.2.[0-1]. (Dataset is 2d-plot-bug-datasets, ask me for this dataset.) * Plot over line. We would like to show log plots of n(Cu), n(Cup) and n(em), but there is a bug. We will display V instead. Specify axis range explicitly to 0, 150. * Now, delete all of the 3d views, and stack the four 2d views vertically on top of each other. See the png file phase_portraits _and_V.png (ask me for this .png). My user creates numerous of these plots per day. >> The goal of this feature request is to create state settings or tools that are more efficient when setting up numerous 2d plots. | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2013-02-19 20:56 | Alan Scott | New Issue | ||||||||
| 2013-02-27 17:06 | Alan Scott | Status | backlog => todo | |||||||
| 2013-02-27 23:01 | Alan Scott | Note Added: 0030395 | ||||||||
| 2013-04-30 16:24 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain | |||||||
| 2013-07-30 10:08 | Utkarsh Ayachit | Target Version | => 4.1 | |||||||
| 2014-01-16 16:47 | Utkarsh Ayachit | Assigned To | Sebastien Jourdain => | |||||||
| 2014-01-16 16:54 | Utkarsh Ayachit | Relationship added | child of 0014521 | |||||||
| 2014-02-07 21:47 | Utkarsh Ayachit | Target Version | 4.1 => 4.2 | |||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Note Added: 0033128 | ||||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Status | todo => gatekeeper review | |||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Resolution | open => no change required | |||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | |||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review | |||||||
| 2014-07-29 10:57 | Utkarsh Ayachit | Fixed in Version | => git-master | |||||||
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 | |||||||
| 2014-09-16 17:32 | Alan Scott | Note Added: 0033352 | ||||||||
| 2014-09-16 17:32 | Alan Scott | Status | customer review => closed | |||||||
| Notes | |||||
