MantisBT - ParaView |
View Issue Details |
0013899 | ParaView | (No Category) | public | 2013-02-19 20:00 | 2013-05-22 21:45 |
Reporter | Alan Scott | |
Assigned To | David Thompson | |
Status | closed | Resolution | fixed | |
Product Version | 3.98.1 | |
Target Version | | Fixed in Version | 4.0 | |
Project | Sandia |
Topic Name | 13876_log_scaled_axes |
Type | incorrect functionality |
Summary | 0013899: 2d plot - log Y axis is broken (problem dataset) |
Description | I am writing up bugs for a problem dataset. I think this is a duplicate of 13876, but am not sure. Thus, I am writing this one up also.
Linux, 3.98.1, local server.
* Open output.e.2.[0-1]. (Dataset is 2d-plot-bug-datasets, ask me for this dataset.)
* All variables on. Apply.
* Plot over line. Apply. Turn all variables on, then off. Then, turn on n(Cu), n(Cup) and n(em).
* View Settings/ Left Axis/ Layout/ - then click "Use Logarithmic Scale When Available".
<<bug>> - left axis stops showing.
* Next, select Axis Labels/ Specify Axis Labels Explicitly.
* Generate. Use 1e8 to 1e17. OK.
<<bug >> All you see on the left axis is Inf. What? This is a bug.
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Relationships | related to | 0013876 | closed | David Thompson | 2d plot - log Y axis is broken | related to | 0013951 | closed | David Thompson | Plots - LogScale - when labels are specified explicitly, they are assumed to be in the unscaled mode. |
Attached Files | |
2013-02-19 20:00 | Alan Scott | New Issue | |
2013-02-19 20:01 | Alan Scott | Relationship added | related to 0013876 |
2013-02-26 10:56 | Utkarsh Ayachit | Assigned To | => David Thompson (old) |
2013-02-27 16:56 | Alan Scott | Note Added: 0030392 | |
2013-02-27 17:04 | Alan Scott | Note Added: 0030393 | |
2013-02-27 17:05 | Alan Scott | Status | backlog => todo |
2013-03-01 00:43 | David Thompson | Assigned To | David Thompson (old) => David Thompson |
2013-03-20 16:50 | Utkarsh Ayachit | Relationship added | related to 0013951 |
2013-03-25 11:58 | David Thompson | Topic Name | => 13876_log_scaled_axes |
2013-03-25 11:58 | David Thompson | Note Added: 0030474 | |
2013-03-25 11:58 | David Thompson | Status | todo => gatekeeper review |
2013-03-25 11:58 | David Thompson | Fixed in Version | => git-next |
2013-03-25 11:58 | David Thompson | Resolution | open => fixed |
2013-03-25 14:43 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-03-25 14:43 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-03-25 14:43 | Utkarsh Ayachit | Note Added: 0030476 | |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-05-22 21:45 | Alan Scott | Note Added: 0030833 | |
2013-05-22 21:45 | Alan Scott | Status | customer review => closed |
(0030392)
Alan Scott
2013-02-27 16:56
Dataset has been renamed large_range_1D_paraview_test_data.e.2.[0-1] |
(0030393)
Alan Scott
2013-02-27 17:04
(0030474)
David Thompson
2013-03-25 11:58
Please see bug 13876 for a summary of the changes.
The test case in the original bug report should now work. Note that for log scaling to become *active* after being *requested* in the axis layout preferences, you must either translate the chart with a click+drag or manually set the axis scale so the origin is no longer included. |
(0030476)
Utkarsh Ayachit
2013-03-25 14:43
SUMMARY
Topics merged into master:
(VTK) 13876_log_scaled_axes
(0030833)
Alan Scott
2013-05-22 21:45
Tested remote server, linux, master. Nice! |
