MantisBT - ParaView
View Issue Details
0013892ParaView(No Category)public2013-02-19 04:092013-09-03 21:29
Maxim
Yumin Yuan
normalminorhave not tried
closedfixed
3.98.1
4.0
ParaViS
13892_polyhedron_vtu
crash
0013892: Does not draw polyhedrons when polyhedrons placed in several piaces in vtu file
When I use polyhedron cells (type 42) in one piece of vtu file in
ParaView-3.98.1-Windows-64bit all is right. Such example you can see in attached
tar archive(file1.vtu). But when I use polyhedron cells (type 42) in several
pieces in vtu file ParaView does draws polyhedrons only from the first piece and does not draw polyhedrons from the other pieces. You can see the simple example in attached tar archive(file2.vtu). Also when I tried to load big vtu file with polyhedrons in several pieces ParaView crashes.
No tags attached.
related to 0014188closed David Thompson Bug on clipping vtkUnstructuredGrid containing Polyhedrons
tar files.tar (6,656) 2013-02-19 04:09
https://www.vtk.org/Bug/file/9398/files.tar
? polyhedron2pieces.vtu (2,483) 2013-04-18 10:02
https://www.vtk.org/Bug/file/9435/polyhedron2pieces.vtu
Issue History
2013-02-19 04:09MaximNew Issue
2013-02-19 04:09MaximFile Added: files.tar
2013-03-12 09:13Utkarsh AyachitStatusbacklog => todo
2013-04-10 12:51Utkarsh AyachitAssigned To => Yumin Yuan
2013-04-11 08:40Yumin YuanStatustodo => active development
2013-04-18 10:01Yumin YuanTopic Name => 13892_polyhedron_vtu
2013-04-18 10:01Yumin YuanNote Added: 0030577
2013-04-18 10:01Yumin YuanStatusactive development => gatekeeper review
2013-04-18 10:01Yumin YuanFixed in Version => git-next
2013-04-18 10:01Yumin YuanResolutionopen => fixed
2013-04-18 10:02Yumin YuanFile Added: polyhedron2pieces.vtu
2013-04-25 09:22Utkarsh AyachitFixed in Versiongit-next => git-master
2013-04-25 09:24Utkarsh AyachitNote Added: 0030610
2013-04-25 09:24Utkarsh AyachitStatusgatekeeper review => customer review
2013-05-18 20:00Utkarsh AyachitFixed in Versiongit-master => 4.0
2013-09-03 21:28Alan ScottRelationship addedrelated to 0014188
2013-09-03 21:29Alan ScottNote Added: 0031533
2013-09-03 21:29Alan ScottStatuscustomer review => closed
Notes
(0030577)
Yumin Yuan
2013-04-18 10:01
There are two places wrong for this bug. First is a real bug in the reader itself; second is that the file attached also contains some errors. Please use the new attached file (polyhedron2pieces.vtu) to test for the bug fix.
(0030610)
Utkarsh Ayachit
2013-04-25 09:24
SUMMARY
Topics merged into master:
        13450_update_tests_to_use_new_panels
(VTK) 14023-plot3d-function-support
        14026_catalyst_python_warning
        14032_fix_CoProcessingTestInput
        fix_protobuf_try_compiles
        pvw-python-refactoring
        pvw-remove-example
        refactor_panels
(VTK) update_vtk_master
        zoom-to-data-icon
        fix_cmake_2.8.10_plugins_issue
(0031533)
Alan Scott
2013-09-03 21:29
I believe this was actually fixed in bug 14188.
Tested Linux, master, local server.
 (Remote server crashes, bug number http://paraview.org/Bug/view.php?id=14258. [^])
