MantisBT - ParaView | |||||
View Issue Details | |||||
0013688 | ParaView | (No Category) | public | 2012-11-28 06:46 | 2016-08-12 09:59 |
Reporter | Sven Buijssen | ||||
Product Version | 3.14.1 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0013688: Client/Server only: Incorrect coloring of data type long. Correct for same data if data type is float | ||||
Description | Start ParaView. Connect to single process PVserver Load attached file. Apply. Color by: "material (float)" Enable color legend visibility => Note: four clearly distinguishable colors used for 3D object Color by: "material (long)" => Note: 3D object only colored in red - despite the fact that the underlying numerical values of "material (float)" and "material (long)" are identical, just the data type differs. Does not happen in builtin mode with ParaView 3.14.1. ParaView 3.98.0 RC3 client/server mode affects, too. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | gmvtest.cs.long.vs.float.vtu (1,856) 2012-11-28 06:49 https://www.vtk.org/Bug/file/9347/gmvtest.cs.long.vs.float.vtu | ||||
Issue History | |||||
2012-11-28 06:46 | Sven Buijssen | New Issue | |||
2012-11-28 06:49 | Sven Buijssen | File Added: gmvtest.cs.long.vs.float.vtu | |||
2012-11-30 07:53 | Sven Buijssen | Note Added: 0029813 | |||
2012-12-24 08:28 | Utkarsh Ayachit | Note Added: 0029943 | |||
2012-12-24 08:29 | Utkarsh Ayachit | Note Edited: 0029943 | bug_revision_view_page.php?bugnote_id=29943#r536 | ||
2012-12-24 09:28 | Utkarsh Ayachit | Note Added: 0029944 | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038285 | |||
Notes | |||||
