MantisBT - VTK
View Issue Details
0013581VTK(No Category)public2012-10-28 14:502013-02-24 19:13
David Gobbi
David Gobbi
normalminorhave not tried
closedfixed
TBD
incorrect functionality
0013581: Wrapped templated classes and module boundaries
TestTemplates has been failing since the vtkTuple was moved from CommonDataModel to CommonMath. Because of the move, the python wrappers no longer recognize vtkTuple as the superclass of vtkVector and vtkColor, resulting in loss of functionality within the python wrappers.
The problem is that vtkWrapPython searches through the module hierarchy file to see what instances of each templated class are used within its own module, but vtkWrapPython cannot know how a templated class might be used in other modules. Hence, vtkWrapPython cannot know what instances of the vtkTuple template are required by the vtkVector header file, because vtkVector.h is in a different module.
The solution could either be a "global view" mechanism or some sort of hinting mechanism, the latter is preferable. The hints for vtkTuple<T,N> would be T=uchar,int,float,double and N=2,3,4.
Another issue is that special wrapper files for non-vtkObjectBase types like vtkVectorPython.cxx do not use import/export macros yet. For each type that is referred to, it will be necessary to check if that type is within the current module (EXPORT) or a different module (IMPORT).
No tags attached.
Issue History
2012-10-28 14:50David GobbiNew Issue
2012-10-28 14:50David GobbiStatusbacklog => tabled
2012-10-28 14:50David GobbiAssigned To => David Gobbi
2013-02-24 19:13David GobbiNote Added: 0030377
2013-02-24 19:13David GobbiStatustabled => closed
2013-02-24 19:13David GobbiResolutionopen => fixed
Notes
(0030377)
David Gobbi
2013-02-24 19:13
Fixed by commit c2bd3fdb on Feb 4, 2013.
