MantisBT - ParaView | |||||
View Issue Details | |||||
0013292 | ParaView | (No Category) | public | 2012-07-02 20:34 | 2016-08-12 09:59 |
Reporter | Nathan Fabian | ||||
Product Version | |||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0013292: Wrong extents in Spyplot reader and corresponding in the AMR filters. | ||||
Description | In vtkAMRDualContour.cxx each reference to GetExtents(extent) is immediately followed by --extent[1]; --extent[3]; --extent[5]; This appears to be due to the Spyplot reader always passing the dimensions as the higher value instead of dimensions - 1. There is code to select between dimensions-1 and dimensions as the upper extent. I think this should instead be dimensions-2 and dimensions-1 and then vtkAMRDualContour should no longer decrement. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-07-02 20:34 | Nathan Fabian | New Issue | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038240 | |||
Notes | |||||
