MantisBT - VTK | |||||
View Issue Details | |||||
0013254 | VTK | (No Category) | public | 2012-06-20 21:53 | 2013-12-27 22:05 |
Reporter | Dale Lukas Peterson | ||||
Assigned To | Dave DeMarle | ||||
Status | closed | Resolution | fixed | ||
Product Version | 6.0.0 | ||||
Target Version | 6.0.1 | Fixed in Version | 6.0.0 | ||
Project | Kitware | ||||
Summary | 0013254: Error including <QVTKWidget.h> | ||||
Description | I have a simple test file, RenderWindow.cxx: #include <QVTKWidget.h> int main() { } with a CMakeLists.txt file: cmake_minimum_required(VERSION 2.8) PROJECT(RenderWindow) FIND_PACKAGE(VTK) INCLUDE(${VTK_USE_FILE}) FIND_PACKAGE(Qt4 REQUIRED) INCLUDE(${QT_USE_FILE}) ADD_EXECUTABLE(RenderWindow RenderWindow.cxx) luke@LenovoW510 ~/tmp/testvtk/qvtk/build $ make Scanning dependencies of target RenderWindow [100%] Building CXX object CMakeFiles/RenderWindow.dir/RenderWindow.cxx.o In file included from /home/luke/usr/include/vtk-6.0/QVTKWidget.h:40:0, from /home/luke/tmp/testvtk/qvtk/RenderWindow.cxx:13: /home/luke/usr/include/vtk-6.0/QVTKInteractor.h:45:52: fatal error: vtkTDxConfigure.h: No such file or directory compilation terminated. make[2]: *** [CMakeFiles/RenderWindow.dir/RenderWindow.cxx.o] Error 1 make[1]: *** [CMakeFiles/RenderWindow.dir/all] Error 2 make: *** [all] Error 2 This is from the master branch (commit d615e721fb8ab8d88fe064b51d2e3cd45921d9c6), when I build and install, vtkTDxConfigure.h is not installed. I am not sure if this file is supposed to be installed or not. I see that Rendering/OpenGL/CMakeLists:39 has a configure_file() statement that I think should be installing the file. For some reason it isn't however. Similarly for various other configure files. I don't know if this is a problem with QVTKWidget.h, or maybe QVTKInteractor.h, or if this is a problem with the build system. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2012-06-20 21:53 | Dale Lukas Peterson | New Issue | |||
2013-06-25 16:24 | Dave DeMarle | Assigned To | => Dave DeMarle | ||
2013-06-25 16:24 | Dave DeMarle | Status | backlog => todo | ||
2013-06-25 16:24 | Dave DeMarle | Product Version | => 6.0.0 | ||
2013-06-25 16:24 | Dave DeMarle | Target Version | => 6.0.1 | ||
2013-07-22 20:04 | Dave DeMarle | Status | todo => backlog | ||
2013-12-27 22:05 | Dave DeMarle | Note Added: 0032076 | |||
2013-12-27 22:05 | Dave DeMarle | Status | backlog => closed | ||
2013-12-27 22:05 | Dave DeMarle | Resolution | open => fixed | ||
2013-12-27 22:05 | Dave DeMarle | Fixed in Version | => 6.0.0 |
Notes | |||||
