MantisBT - VTK | |||||
| View Issue Details | |||||
| 0013174 | VTK | (No Category) | public | 2012-05-14 11:47 | 2014-10-02 17:10 |
| Reporter | Sean McBride | ||||
| Assigned To | Chuck Atkins | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | unable to reproduce | ||
| Product Version | |||||
| Target Version | Fixed in Version | ||||
| Project | TBD | ||||
| Type | incorrect functionality | ||||
| Summary | 0013174: incremental build dependency problem toggling VTK_USE_64BIT_IDS | ||||
| Description | Repro: - build VTK 5.10rc4 with BUILD_TESTING=1 - toggle VTK_USE_64BIT_IDS from its default - don't 'clean' - rebuild Results: - link errors: Undefined symbols for architecture x86_64: "__ZN12LSDynaFamily10SkipToWordENS_11SectionTypeEii", referenced from: __ZN15vtkLSDynaReader21ReadHeaderInformationEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader21ScanDatabaseTimeStepsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader9ReadNodesEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader11ReadUserIdsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader17ReadNodeStateInfoEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader12ReadSPHStateEi in libvtkIO.a(vtkLSDynaReader.cxx.o) __ZN15vtkLSDynaReader19ReadUserMaterialIdsEv in libvtkIO.a(vtkLSDynaReader.cxx.o) ... VTK has an incremental build dependency problem. When you build and then change the setting of VTK_USE_64BIT_IDS, and rebuild, Utilities/LSDyna sees the one definition of vtkIdType (64bit), and the rest of the build sees the other (32bit) (or vice versa). Doing a 'make clean' and then a 'make' is a workaround. A proper bug fix is to make CMake aware that changing this flag requires a complete rebuild (like compiler flags do). | ||||
| Steps To Reproduce | |||||
| Tags | hackaton | ||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2012-05-14 11:47 | Sean McBride | New Issue | |||
| 2012-05-14 11:47 | Sean McBride | Status | backlog => tabled | ||
| 2012-05-14 11:47 | Sean McBride | Assigned To | => Dave DeMarle | ||
| 2012-10-03 17:57 | Sean McBride | Note Added: 0029317 | |||
| 2013-07-22 20:02 | Dave DeMarle | Status | tabled => backlog | ||
| 2013-07-22 20:02 | Dave DeMarle | Note Added: 0031243 | |||
| 2014-09-30 11:01 | Dave DeMarle | Assigned To | Dave DeMarle => | ||
| 2014-10-02 11:37 | Berk Geveci | Tag Attached: hackaton | |||
| 2014-10-02 11:38 | Berk Geveci | Assigned To | => Chuck Atkins | ||
| 2014-10-02 15:35 | Chuck Atkins | Status | backlog => active development | ||
| 2014-10-02 17:10 | Chuck Atkins | Note Added: 0033549 | |||
| 2014-10-02 17:10 | Chuck Atkins | Status | active development => closed | ||
| 2014-10-02 17:10 | Chuck Atkins | Resolution | open => unable to reproduce | ||
| Notes | |||||
