MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0013096 | ParaView | Feature | public | 2012-04-13 11:16 | 2016-08-12 09:59 |
| Reporter | Ian Curington | ||||
| Assigned To | Kitware Robot | ||||
| Priority | high | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 3.14.1 | ||||
| Target Version | Fixed in Version | ||||
| Project | ParaViewPro | ||||
| Topic Name | |||||
| Type | incorrect functionality | ||||
| Summary | 0013096: Fix Cancel action on Fix Path in State Files dialog | ||||
| Description | PROBLEM: Cancel of data path dialog continues to load possibly incorrect data paths. SOLUTION: Add canceling of entire loading of state file after clicking on 'X' or 'Cancel' button in "Fix Paths in State Files" dialog. patched files: pqApplicationCore.[h, cxx], pqFixPathsInStateFilesBehavior.cxx action: copy pqApplicationCore.* to ParaView-3.14.0/Qt/Core copy pqFixPathsInStateFilesBehavior.cxx to ParaView-3.14.0/Qt/ApplicationComponents DESCRIPTION: When user loads state file with filenames specified in it, dialog pops up to allow user to update filenames paths. In case user clicks on Cancel or 'X' button, patch allows stopping entire process of loading of state files, instead of stopping only fixing pathnames in state file being loaded as it was previously done. Perhaps previous behavior was intended feature, but canceling of entire loading process when user clicks on 'X' or 'Cancel' looks much more natural than continuing with loading of state file. CHANGES: To make this patch, following changes were made (ParaView source patch): - Added QuitLoadingStateFile property and its mutator to pqApplicationCore class, - Added logic of quiting loading of state file in case flag is set in pqApplicationCore::loadStateFile() routine, - Added setting of pqApplicationCore::QuitLoadingStateFile flag in pqFixPathsInStateFilesBehavior class. | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | https://www.vtk.org/Bug/file/9173/pqApplicationCore.h https://www.vtk.org/Bug/file/9174/pqApplicationCore.cxx https://www.vtk.org/Bug/file/9175/pqFixPathsInStateFilesBehavior.cxx | ||||
| Issue History | |||||
| 2012-04-13 11:16 | Ian Curington | New Issue | |||
| 2012-04-13 11:16 | Ian Curington | File Added: pqApplicationCore.h | |||
| 2012-04-13 11:17 | Ian Curington | File Added: pqApplicationCore.cxx | |||
| 2012-04-13 11:18 | Ian Curington | File Added: pqFixPathsInStateFilesBehavior.cxx | |||
| 2012-04-23 10:36 | Utkarsh Ayachit | Note Added: 0028514 | |||
| 2012-04-23 10:36 | Utkarsh Ayachit | Category | (No Category) => Feature | ||
| 2012-04-23 10:41 | Utkarsh Ayachit | Project | TBD => ParaViewPro | ||
| 2012-05-14 05:14 | Nenad Vujicic | Note Added: 0028600 | |||
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038192 | |||
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed | ||
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved | ||
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot | ||
| Notes | |||||
