MantisBT - ParaView | |||||
View Issue Details | |||||
0012967 | ParaView | (No Category) | public | 2012-02-28 15:00 | 2016-08-12 09:59 |
Reporter | Ann Moulding | ||||
Product Version | 3.14 | ||||
Project | TBD | ||||
Topic Name | |||||
Summary | 0012967: Calculator choking on data with "text" fields. | ||||
Description | Using a series of CSV files (and running Table to Points and 2DDelaunay polygon filters successfully on the files) I try using the Calculator filter to create vectors to plot with the Glyph tool. But when I use the calculator – one of the “Point Data” fields (arrays) is not numeric – and when I write my formula (which does not use the non-numeric field) and hit “Apply” - the Output message says ERROR: In ..\..\..\..\source\VTK\Graphics\vtkArrayCalculator.cxx, line 304 vtkPVArrayCalculator (000000000B39EAE0): Invalid array name: 'Name' (the name of the non numeric field is “Name”). I tried renaming this field in the input file – and this didn’t work. So I removed the non-numeric field completely from the input file – and the calculator did work. I believe the calculator somehow gets choked if there is a text array in a file. I am attaching the CSV file that I am trying to work with. The formula I am trying to apply to this is: iHat* 'FLOFx' + jHat * 'FLOFz'+ kHat * 0. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | TOUGH2_0000.csv (322,591) 2012-02-28 15:00 https://www.vtk.org/Bug/file/9123/TOUGH2_0000.csv | ||||
Issue History | |||||
2012-02-28 15:00 | Ann Moulding | New Issue | |||
2012-02-28 15:00 | Ann Moulding | File Added: TOUGH2_0000.csv | |||
2016-08-12 09:59 | Kitware Robot | Note Added: 0038150 | |||
Notes | |||||
