MantisBT - ParaView | |||||
View Issue Details | |||||
0012787 | ParaView | (No Category) | public | 2011-12-09 10:26 | 2015-01-11 08:35 |
Reporter | mycae | ||||
Status | closed | Resolution | fixed | ||
Product Version | 3.10.1 | ||||
Target Version | Fixed in Version | 3.14 | |||
Project | TBD | ||||
Topic Name | 12787_segfault_opening_raw_files | ||||
Type | crash | ||||
Summary | 0012787: Crash in Exopen.c CanReadFile | ||||
Description | The attached file causes a segfault when doing file->open then selecting "raw", then crash. Here is the backtrace System: Linux 2.6.34.10-0.4-desktop #1 SMP PREEMPT 2011-10-19 22:16:41 +0200 x86_64 X Vendor: The X.Org Foundation X Vendor Release: 10800000 Selinux: No Accessibility: Disabled GTK+ Theme: Clearlooks Icon Theme: Gilouche GTK+ Modules: canberra-gtk-module, gnomebreakpad Memory status: size: 593018880 vsize: 593018880 resident: 116469760 share: 82341888 rss: 116469760 rss_rlim: 18446744073709551615 CPU usage: start_time: 1323443565 rtime: 199 utime: 118 stime: 81 cutime:0 cstime: 0 timeout: 0 it_real_value: 0 frequency: 100 Backtrace was generated from '/usr/lib64/paraview/paraview' [Thread debugging using libthread_db enabled] 0x00007fc9429c5e3e in waitpid () from /lib64/libpthread.so.0 #0 0x00007fc9429c5e3e in waitpid () from /lib64/libpthread.so.0 #1 0x00007fc93c345189 in g_spawn_sync () from /usr/lib64/libglib-2.0.so.0 #2 0x00007fc93c3456c9 in g_spawn_command_line_sync () from /usr/lib64/libglib-2.0.so.0 #3 0x00007fc92d6ec9f0 in ?? () from /usr/lib64/gtk-2.0/modules/libgnomebreakpad.so #4 <signal handler called> #5 0x00007fc93d0959d5 in raise () from /lib64/libc.so.6 #6 0x00007fc93d096ed6 in abort () from /lib64/libc.so.6 #7 0x00007fc93d0d0cb3 in __libc_message () from /lib64/libc.so.6 #8 0x00007fc93d14a157 in __fortify_fail () from /lib64/libc.so.6 0000009 0x00007fc93d147f00 in __chk_fail () from /lib64/libc.so.6 #10 0x00007fc93d147279 in _IO_str_chk_overflow () from /lib64/libc.so.6 0000011 0x00007fc93d0d4135 in _IO_default_xsputn_internal () from /lib64/libc.so.6 #12 0x00007fc93d0a8f57 in vfprintf () from /lib64/libc.so.6 #13 0x00007fc93d14731d in __vsprintf_chk () from /lib64/libc.so.6 #14 0x00007fc93d14725f in __sprintf_chk () from /lib64/libc.so.6 #15 0x00007fc938065664 in sprintf (path= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"..., mode=<value optimized out>, comp_ws=0x7fff9348617c, io_ws=0x7fff93486178, version=0x7fff93486174, run_version=<value optimized out>) at /usr/include/bits/stdio2.h:34 #16 vtk_exodus_ex_open_int (path= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"..., mode=<value optimized out>, comp_ws=0x7fff9348617c, io_ws=0x7fff93486178, version=0x7fff93486174, run_version=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/VTK/Utilities/vtkexodus2/exopen.c:131 #17 0x00007fc94334d62d in vtkExodusIIReader::CanReadFile (this=0x1ec3cd0, fname= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"...) at /usr/src/packages/BUILD/ParaView-3.10.1/VTK/Hybrid/vtkExodusIIReader.cxx:5390 #18 0x00007fc944f65822 in vtkExodusIIReaderCommand (arlu=0x10ba0f0, ob= 0x1ec3cd0, method=0x1faeb49 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Utilities/VTKClientServer/Hybrid/vtkExodusIIReaderClientServer.cxx:92 #19 0x00007fc944f741e3 in vtkPExodusIIReaderCommand (arlu=0x10ba0f0, ob= 0x1ec3cd0, method=0x1faeb49 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Utilities/VTKClientServer/Hybrid/vtkPExodusIIReaderClientServer.cxx:239 #20 0x00007fc940fd6bf7 in vtkClientServerInterpreter::ProcessCommandInvoke ( this=0x10ba0f0, css=..., midx=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:379 #21 0x00007fc940fd9785 in vtkClientServerInterpreter::ProcessOneMessage (this= 0x10ba0f0, css=..., message=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:214 #22 0x00007fc940fd9abd in vtkClientServerInterpreter::ProcessStream (this= 0x10ba0f0, css=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:183 #23 0x00007fc94ac7cebb in vtkFileSeriesReader::CanReadFile (reader=0x1ec3cd0, filename= 0x1f85248 "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Filters/vtkFileSeriesReader.cxx:483 #24 0x00007fc94ac7cfec in vtkFileSeriesReader::CanReadFile (this=0x1eb5120, filename=0x1f0108d "/home/user/work/code/dir1/code/tip_imgs.dat") at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Filters/vtkFileSeriesReader.cxx:451 #25 0x00007fc94b21861e in vtkFileSeriesReaderCommand (arlu=0x10ba0f0, ob= 0x1eb5120, method=0x1f01079 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Servers/Filters/vtkFileSeriesReaderClientServer.cxx:111 #26 0x00007fc94b2163e7 in vtkExodusFileSeriesReaderCommand (arlu=0x10ba0f0, ob= 0x1eb5120, method=0x1f01079 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Servers/Filters/vtkExodusFileSeriesReaderClientServer.cxx:87 #27 0x00007fc940fd6bf7 in vtkClientServerInterpreter::ProcessCommandInvoke ( this=0x10ba0f0, css=..., midx=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:379 #28 0x00007fc940fd9785 in vtkClientServerInterpreter::ProcessOneMessage (this= 0x10ba0f0, css=..., message=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:214 #29 0x00007fc940fd9abd in vtkClientServerInterpreter::ProcessStream (this= 0x10ba0f0, css=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:183 #30 0x00007fc94721b8b0 in vtkSelfConnection::ProcessStreamLocally ( this=<value optimized out>, stream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkSelfConnection.cxx:118 #31 0x00007fc9471b0247 in vtkProcessModuleConnection::SendStream (this= 0x1845b50, servers=<value optimized out>, stream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModuleConnection.cxx:241 #32 0x00007fc9471b1cb6 in vtkProcessModuleConnectionManager::SendStream ( this=<value optimized out>, connectionID=<value optimized out>, serverFlags=2, stream=..., reset=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModuleConnectionManager.cxx:541 #33 0x00007fc9471b8c73 in vtkProcessModule::SendStream (this=0x10e3330, connectionID=5, server=2, stream=..., resetStream=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModule.cxx:919 #34 0x00007fc94b63d95c in vtkSMReaderFactory::CanReadFile (filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", prworky= 0x1e968d0) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:641 #35 0x00007fc94b63dbe9 in vtkSMReaderFactory::vtkInternals::vtkValue::CanReadFile (this=<value optimized out>, filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", extensions=std::vector of length 0, capacity 0, cid=5, skip_filename_test= true) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:250 #36 0x00007fc94b63dd89 in vtkSMReaderFactory::GetPossibleReaders (this= 0xf410a0, filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", cid=5) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:490 #37 0x00007fc94cae4bd3 in pqSelectReaderDialog::pqSelectReaderDialog (this= 0x7fff93487060, file=..., s=<value optimized out>, readerFactory=0xf410a0, p=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/Components/pqSelectReaderDialog.cxx:68 #38 0x00007fc94cea025a in pqLoadDataReaction::DetermineFileReader (filename= ..., server=0x1845850, factory=0xf410a0, readerInfo=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:215 #39 0x00007fc94cea1962 in pqLoadDataReaction::loadData ( files=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:149 #40 0x00007fc94cea2258 in pqLoadDataReaction::loadData () at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:94 #41 0x00007fc94cec527c in pqLoadDataReaction::onTriggered (this=0x17d27c0) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/../../../Qt/ApplicationComponents/pqLoadDataReaction.h:83 #42 0x00007fc94cec64a2 in pqReaction::qt_metacall (this=0x17d27c0, _c= QMetaObject::InvokeMetaMethod, _id=<value optimized out>, _a=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/moc_pqReaction.cxx:72 #43 0x00007fc94cec51c0 in pqLoadDataReaction::qt_metacall (this=0x17d27c0, _c= QMetaObject::InvokeMetaMethod, _id=<value optimized out>, _a= 0x7fff934875f0) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/moc_pqLoadDataReaction.cxx:71 #44 0x00007fc94782088f in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib64/libQtCore.so.4 #45 0x00007fc9485a2d92 in QAction::triggered(bool) () from /usr/lib64/libQtGui.so.4 #46 0x00007fc9485a2f8a in QAction::activate(QAction::ActionEvent) () from /usr/lib64/libQtGui.so.4 #47 0x00007fc9485a3107 in QAction::event(QEvent*) () from /usr/lib64/libQtGui.so.4 #48 0x00007fc9485a9114 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 0000049 0x00007fc9485b16aa in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 #50 0x00007fc94780b63c in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/libQtCore.so.4 #51 0x00007fc9485db9b0 in ?? () from /usr/lib64/libQtGui.so.4 #52 0x00007fc9485dcea8 in ?? () from /usr/lib64/libQtGui.so.4 #53 0x00007fc9485b326c in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 0000054 0x00007fc94780b63c in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/libQtCore.so.4 0000055 0x00007fc94864aa4a in ?? () from /usr/lib64/libQtGui.so.4 #56 0x00007fc94864aecd in ?? () from /usr/lib64/libQtGui.so.4 #57 0x00007fc948626fcc in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib64/libQtGui.so.4 #58 0x00007fc94864eef2 in ?? () from /usr/lib64/libQtGui.so.4 #59 0x00007fc93c301a93 in g_main_context_dispatch () from /usr/lib64/libglib-2.0.so.0 0000060 0x00007fc93c302270 in ?? () from /usr/lib64/libglib-2.0.so.0 #61 0x00007fc93c302510 in g_main_context_iteration () from /usr/lib64/libglib-2.0.so.0 #62 0x00007fc94783630f in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 #63 0x00007fc94864eb8e in ?? () from /usr/lib64/libQtGui.so.4 #64 0x00007fc94780aa72 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 #65 0x00007fc94780ac85 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 #66 0x00007fc94780f0eb in QCoreApplication::exec() () from /usr/lib64/libQtCore.so.4 0000067 0x0000000000406a47 in main (argc=1, argv=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Applications/ParaView/paraview_main.cxx:82 Thread 1 (Thread 0x7fc94d2a67a0 (LWP 8955)): #0 0x00007fc9429c5e3e in waitpid () from /lib64/libpthread.so.0 No symbol table info available. #1 0x00007fc93c345189 in g_spawn_sync () from /usr/lib64/libglib-2.0.so.0 No symbol table info available. #2 0x00007fc93c3456c9 in g_spawn_command_line_sync () from /usr/lib64/libglib-2.0.so.0 No symbol table info available. #3 0x00007fc92d6ec9f0 in ?? () from /usr/lib64/gtk-2.0/modules/libgnomebreakpad.so No symbol table info available. #4 <signal handler called> No symbol table info available. #5 0x00007fc93d0959d5 in raise () from /lib64/libc.so.6 No symbol table info available. #6 0x00007fc93d096ed6 in abort () from /lib64/libc.so.6 No symbol table info available. #7 0x00007fc93d0d0cb3 in __libc_message () from /lib64/libc.so.6 No symbol table info available. #8 0x00007fc93d14a157 in __fortify_fail () from /lib64/libc.so.6 No symbol table info available. 0000009 0x00007fc93d147f00 in __chk_fail () from /lib64/libc.so.6 No symbol table info available. #10 0x00007fc93d147279 in _IO_str_chk_overflow () from /lib64/libc.so.6 No symbol table info available. 0000011 0x00007fc93d0d4135 in _IO_default_xsputn_internal () from /lib64/libc.so.6 No symbol table info available. #12 0x00007fc93d0a8f57 in vfprintf () from /lib64/libc.so.6 No symbol table info available. #13 0x00007fc93d14731d in __vsprintf_chk () from /lib64/libc.so.6 No symbol table info available. #14 0x00007fc93d14725f in __sprintf_chk () from /lib64/libc.so.6 No symbol table info available. #15 0x00007fc938065664 in sprintf (path= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"..., mode=<value optimized out>, comp_ws=0x7fff9348617c, io_ws=0x7fff93486178, version=0x7fff93486174, run_version=<value optimized out>) at /usr/include/bits/stdio2.h:34 No locals. #16 vtk_exodus_ex_open_int (path= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"..., mode=<value optimized out>, comp_ws=0x7fff9348617c, io_ws=0x7fff93486178, version=0x7fff93486174, run_version=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/VTK/Utilities/vtkexodus2/exopen.c:131 exoid = <value optimized out> status = <value optimized out> old_fill = 32713 file_wordsize = <value optimized out> errmsg = "Error: failed to open /home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211" #17 0x00007fc94334d62d in vtkExodusIIReader::CanReadFile (this=0x1ec3cd0, fname= 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"...) at /usr/src/packages/BUILD/ParaView-3.10.1/VTK/Hybrid/vtkExodusIIReader.cxx:5390 exoid = <value optimized out> appWordSize = 8 diskWordSize = 8 version = 0 #18 0x00007fc944f65822 in vtkExodusIIReaderCommand (arlu=0x10ba0f0, ob= 0x1ec3cd0, method=0x1faeb49 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Utilities/VTKClientServer/Hybrid/vtkExodusIIReaderClientServer.cxx:92 temp0 = 0x1faeb5d "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"... temp20 = <value optimized out> vtkmsg = {<vtkOStreamWrapper> = {_vptr.vtkOStreamWrapper = 0x1a, ostr = @0x4}, Result = 0x7fff93486d70 "\020\022\360\001", Frozen = 1090388734} #19 0x00007fc944f741e3 in vtkPExodusIIReaderCommand (arlu=0x10ba0f0, ob= 0x1ec3cd0, method=0x1faeb49 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Utilities/VTKClientServer/Hybrid/vtkPExodusIIReaderClientServer.cxx:239 vtkmsg = {<vtkOStreamWrapper> = {_vptr.vtkOStreamWrapper = 0x7fc9433f4a94, ostr = @0x7fc93d67b7d0}, Result = 0x1 <Address 0x1 out of bounds>, Frozen = 1128221332} #20 0x00007fc940fd6bf7 in vtkClientServerInterpreter::ProcessCommandInvoke ( this=0x10ba0f0, css=..., midx=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:379 func = <value optimized out> msg = {Internal = 0x1ed2ab0} obj = 0x1ec3cd0 method = 0x1faeb49 "CanReadFile" #21 0x00007fc940fd9785 in vtkClientServerInterpreter::ProcessOneMessage (this= 0x10ba0f0, css=..., message=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:214 result = 0 cmd = vtkClientServerStream::Invoke #22 0x00007fc940fd9abd in vtkClientServerInterpreter::ProcessStream (this= 0x10ba0f0, css=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:183 i = 1 #23 0x00007fc94ac7cebb in vtkFileSeriesReader::CanReadFile (reader=0x1ec3cd0, filename= 0x1f85248 "/home/user/work/code/dir1/code/;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260\211?;\260"...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Filters/vtkFileSeriesReader.cxx:483 canRead = 1 pm = 0x10e3330 interp = 0x10ba0f0 stream = {Internal = 0x1f00ef0} csId = {ID = 214} #24 0x00007fc94ac7cfec in vtkFileSeriesReader::CanReadFile (this=0x1eb5120, filename=0x1f0108d "/home/user/work/code/dir1/code/tip_imgs.dat") at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Filters/vtkFileSeriesReader.cxx:451 dataFiles = {<vtkSmartPointerBase> = {Object = 0x1ed2a20}, <No data fields>} #25 0x00007fc94b21861e in vtkFileSeriesReaderCommand (arlu=0x10ba0f0, ob= 0x1eb5120, method=0x1f01079 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Servers/Filters/vtkFileSeriesReaderClientServer.cxx:111 temp0 = 0x1f0108d "/home/user/work/code/dir1/code/tip_imgs.dat" temp20 = <value optimized out> vtkmsg = {<vtkOStreamWrapper> = {_vptr.vtkOStreamWrapper = 0x7fc93d3beed8, ostr = @0x19}, Result = 0x32 <Address 0x32 out of bounds>, Frozen = 25} #26 0x00007fc94b2163e7 in vtkExodusFileSeriesReaderCommand (arlu=0x10ba0f0, ob= 0x1eb5120, method=0x1f01079 "CanReadFile", msg=..., resultStream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Servers/Filters/vtkExodusFileSeriesReaderClientServer.cxx:87 vtkmsg = {<vtkOStreamWrapper> = {_vptr.vtkOStreamWrapper = 0x1, ostr = @0x7fc93d0db02c}, Result = 0x1063660 "", Frozen = 1090346134} #27 0x00007fc940fd6bf7 in vtkClientServerInterpreter::ProcessCommandInvoke ( this=0x10ba0f0, css=..., midx=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:379 func = <value optimized out> msg = {Internal = 0x1f00580} obj = 0x1eb5120 method = 0x1f01079 "CanReadFile" #28 0x00007fc940fd9785 in vtkClientServerInterpreter::ProcessOneMessage (this= 0x10ba0f0, css=..., message=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:214 result = 0 cmd = vtkClientServerStream::Invoke #29 0x00007fc940fd9abd in vtkClientServerInterpreter::ProcessStream (this= 0x10ba0f0, css=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Utilities/VTKClientServer/vtkClientServerInterpreter.cxx:183 i = 1 #30 0x00007fc94721b8b0 in vtkSelfConnection::ProcessStreamLocally ( this=<value optimized out>, stream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkSelfConnection.cxx:118 pm = <value optimized out> #31 0x00007fc9471b0247 in vtkProcessModuleConnection::SendStream (this= 0x1845b50, servers=<value optimized out>, stream=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModuleConnection.cxx:241 sendflag = <value optimized out> #32 0x00007fc9471b1cb6 in vtkProcessModuleConnectionManager::SendStream ( this=<value optimized out>, connectionID=<value optimized out>, serverFlags=2, stream=..., reset=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModuleConnectionManager.cxx:541 conn = <value optimized out> #33 0x00007fc9471b8c73 in vtkProcessModule::SendStream (this=0x10e3330, connectionID=5, server=2, stream=..., resetStream=1) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/Common/vtkProcessModule.cxx:919 ret = <value optimized out> #34 0x00007fc94b63d95c in vtkSMReaderFactory::CanReadFile (filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", prworky= 0x1e968d0) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:641 canRead = 1 pm = 0x10e3330 stream = {Internal = 0x1ec3a80} #35 0x00007fc94b63dbe9 in vtkSMReaderFactory::vtkInternals::vtkValue::CanReadFile (this=<value optimized out>, filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", extensions=std::vector of length 0, capacity 0, cid=5, skip_filename_test= true) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:250 pxm = 0xf41040 prototype = <value optimized out> prworky = 0x1e968d0 canRead = <value optimized out> #36 0x00007fc94b63dd89 in vtkSMReaderFactory::GetPossibleReaders (this= 0xf410a0, filename= 0x1f29ae8 "/home/user/work/code/dir1/code/tip_imgs.dat", cid=5) at /usr/src/packages/BUILD/ParaView-3.10.1/Servers/ServerManager/vtkSMReaderFactory.cxx:490 extensions = std::vector of length 0, capacity 0 #37 0x00007fc94cae4bd3 in pqSelectReaderDialog::pqSelectReaderDialog (this= 0x7fff93487060, file=..., s=<value optimized out>, readerFactory=0xf410a0, p=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/Components/pqSelectReaderDialog.cxx:68 info = {static null = {<No data fields>}, static shared_null = {ref = { _q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = {ref = { _q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0x18977e0, static codecForCStrings = 0x0} lw = 0x1f23d30 readers = <value optimized out> #38 0x00007fc94cea025a in pqLoadDataReaction::DetermineFileReader (filename= ..., server=0x1845850, factory=0xf410a0, readerInfo=...) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:215 prompt = {<QDialog> = {<No data fields>}, static staticMetaObject = { d = {superdata = 0x7fc9490629e0, stringdata = 0x7fc94cb7f9a0 "pqSelectReaderDialog", data = 0x7fc94cb7f9c0, extradata = 0x0}}, Internal = 0x1f2f5b0} readerType = {static null = {<No data fields>}, static shared_null = { ref = {_q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = { ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0xb6c6c0, static codecForCStrings = 0x0} readerGroup = {static null = {<No data fields>}, static shared_null = { ref = {_q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = { ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0xb6c6c0, static codecForCStrings = 0x0} list = 0x5 #39 0x00007fc94cea1962 in pqLoadDataReaction::loadData ( files=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:149 valid = <value optimized out> readerInfo = {first = {static null = {<No data fields>}, static shared_null = {ref = {_q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = {ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0xb6c6c0, static codecForCStrings = 0x0}, second = { static null = {<No data fields>}, static shared_null = {ref = { _q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = { ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0xb6c6c0, static codecForCStrings = 0x0}} filename = {static null = {<No data fields>}, static shared_null = { ref = {_q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = { ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0x1e99ba0, static codecForCStrings = 0x0} fi = {d_ptr = {d = 0x1e5b500}} _container_ = {c = {{p = {static shared_null = {ref = {_q_value = 7431}, alloc = 0, begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x1ee7bf0}, d = 0x1ee7bf0}}, brk = 0, i = {i = 0x1ee7c08}, e = {i = 0x1ee7c10}} readerFactory = 0xf410a0 file = {<QList<QString>> = {{p = {static shared_null = {ref = { _q_value = 7431}, alloc = 0, begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x1f5e480}, d = 0x1f5e480}}, <No data fields>} server = 0x1845850 reader = <value optimized out> extensionToReaderSelection = {{d = 0x1f2e640, e = 0x1f2e640}} #40 0x00007fc94cea2258 in pqLoadDataReaction::loadData () at /usr/src/packages/BUILD/ParaView-3.10.1/Qt/ApplicationComponents/pqLoadDataReaction.cxx:94 files = {{p = {static shared_null = {ref = {_q_value = 7431}, alloc = 0, begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x1ee7bf0}, d = 0x1ee7bf0}} readerFactory = <value optimized out> filters = {static null = {<No data fields>}, static shared_null = { ref = {_q_value = 6695}, alloc = 0, size = 0, data = 0xb6c6da, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, static shared_empty = { ref = {_q_value = 7}, alloc = 0, size = 0, data = 0x7fc947b3e8fa, clean = 0, simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d = 0x1e6f350, static codecForCStrings = 0x0} fileDialog = {<QDialog> = {<No data fields>}, static staticMetaObject = {d = {superdata = 0x7fc9490629e0, stringdata = 0x7fc94c62cb80 "pqFileDialog", data = 0x7fc94c62cde0, extradata = 0x0}}, Implementation = 0x1e45640} server = 0x1845850 sources = {{p = {static shared_null = {ref = {_q_value = 7431}, alloc = 0, begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x7fc947b3e800}, d = 0x7fc947b3e800}} #41 0x00007fc94cec527c in pqLoadDataReaction::onTriggered (this=0x17d27c0) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/../../../Qt/ApplicationComponents/pqLoadDataReaction.h:83 sources = {{p = {static shared_null = {ref = {_q_value = 7431}, alloc = 0, begin = 0, end = 0, sharable = 1, array = {0x0}}, d = 0x7fc947b3e800}, d = 0x7fc947b3e800}} source = <value optimized out> #42 0x00007fc94cec64a2 in pqReaction::qt_metacall (this=0x17d27c0, _c= QMetaObject::InvokeMetaMethod, _id=<value optimized out>, _a=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/moc_pqReaction.cxx:72 No locals. #43 0x00007fc94cec51c0 in pqLoadDataReaction::qt_metacall (this=0x17d27c0, _c= QMetaObject::InvokeMetaMethod, _id=<value optimized out>, _a= 0x7fff934875f0) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Qt/ApplicationComponents/moc_pqLoadDataReaction.cxx:71 No locals. #44 0x00007fc94782088f in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib64/libQtCore.so.4 No symbol table info available. #45 0x00007fc9485a2d92 in QAction::triggered(bool) () from /usr/lib64/libQtGui.so.4 No symbol table info available. #46 0x00007fc9485a2f8a in QAction::activate(QAction::ActionEvent) () from /usr/lib64/libQtGui.so.4 No symbol table info available. #47 0x00007fc9485a3107 in QAction::event(QEvent*) () from /usr/lib64/libQtGui.so.4 No symbol table info available. #48 0x00007fc9485a9114 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 No symbol table info available. 0000049 0x00007fc9485b16aa in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 No symbol table info available. #50 0x00007fc94780b63c in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/libQtCore.so.4 No symbol table info available. #51 0x00007fc9485db9b0 in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #52 0x00007fc9485dcea8 in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #53 0x00007fc9485b326c in QApplication::notify(QObject*, QEvent*) () from /usr/lib64/libQtGui.so.4 No symbol table info available. 0000054 0x00007fc94780b63c in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib64/libQtCore.so.4 No symbol table info available. 0000055 0x00007fc94864aa4a in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #56 0x00007fc94864aecd in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #57 0x00007fc948626fcc in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib64/libQtGui.so.4 No symbol table info available. #58 0x00007fc94864eef2 in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #59 0x00007fc93c301a93 in g_main_context_dispatch () from /usr/lib64/libglib-2.0.so.0 No symbol table info available. 0000060 0x00007fc93c302270 in ?? () from /usr/lib64/libglib-2.0.so.0 No symbol table info available. #61 0x00007fc93c302510 in g_main_context_iteration () from /usr/lib64/libglib-2.0.so.0 No symbol table info available. #62 0x00007fc94783630f in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 No symbol table info available. #63 0x00007fc94864eb8e in ?? () from /usr/lib64/libQtGui.so.4 No symbol table info available. #64 0x00007fc94780aa72 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 No symbol table info available. #65 0x00007fc94780ac85 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib64/libQtCore.so.4 No symbol table info available. #66 0x00007fc94780f0eb in QCoreApplication::exec() () from /usr/lib64/libQtCore.so.4 No symbol table info available. 0000067 0x0000000000406a47 in main (argc=1, argv=<value optimized out>) at /usr/src/packages/BUILD/ParaView-3.10.1/temp_dir/Applications/ParaView/paraview_main.cxx:82 qtapp = <incomplete type> pvInitializer = {PVApp = 0xe2aba0, MainWindow = 0xe2dcd0, Splash = 0x161cad0} A debugging session is active. Inferior 1 [process 8955] will be detached. Quit anyway? (y or n) [answered Y; input not from terminal] ----------- .xsession-errors --------------------- warning: found `typeinfo name for vtkDSPFilterGroup' instead warning: can't find linker symbol for virtual table for `vtkOStrStreamWrapper' value warning: can't find linker symbol for virtual table for `QString' value warning: can't find linker symbol for virtual table for `QString' value warning: can't find linker symbol for virtual table for `QPair<QString, QString>' value warning: can't find linker symbol for virtual table for `QString' value warning: can't find linker symbol for virtual table for `QString' value warning: can't find linker symbol for virtual table for `QList<pqPipelineSource*>' value warning: found `QLinkedListData::shared_null' instead warning: can't find linker symbol for virtual table for `QListData' value warning: found `QLinkedListData::shared_null' instead warning: can't find linker symbol for virtual table for `QList<pqPipelineSource*>' value warning: found `QLinkedListData::shared_null' instead warning: can't find linker symbol for virtual table for `QListData' value warning: found `QLinkedListData::shared_null' instead -------------------------------------------------- | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | image.tar.gz (98,905) 2011-12-09 10:26 https://www.vtk.org/Bug/file/9088/image.tar.gz | ||||
Issue History | |||||
2011-12-09 10:26 | mycae | New Issue | |||
2011-12-09 10:26 | mycae | File Added: image.tar.gz | |||
2011-12-09 10:28 | mycae | Note Added: 0027781 | |||
2012-01-13 17:23 | Utkarsh Ayachit | Topic Name | => 12787_segfault_opening_raw_files | ||
2012-01-13 17:23 | Utkarsh Ayachit | Note Added: 0027940 | |||
2012-01-13 17:23 | Utkarsh Ayachit | Status | backlog => gatekeeper review | ||
2012-01-13 17:23 | Utkarsh Ayachit | Fixed in Version | => git-next | ||
2012-01-13 17:23 | Utkarsh Ayachit | Resolution | open => fixed | ||
2012-01-13 17:23 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit | ||
2012-01-20 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review | ||
2012-01-20 14:20 | Utkarsh Ayachit | Note Added: 0027955 | |||
2012-01-20 14:21 | Utkarsh Ayachit | Fixed in Version | git-next => git-master | ||
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 | ||
2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed | ||
2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028124 | |||
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bcd5871b | ||
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 763df395 |
Notes | |||||
