MantisBT - ParaView |
| View Issue Details |
| 0012745 | ParaView | Feature | public | 2011-11-22 11:15 | 2012-02-08 17:26 |
| Reporter | Utkarsh Ayachit | |
| Assigned To | Utkarsh Ayachit | |
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | 3.12 | |
| Target Version | | Fixed in Version | 3.14 | |
| Project | ParaViS |
| Topic Name | 12745_help_from_plugins |
| Type | incorrect functionality |
| Summary | 0012745: Add support for incorporate documentation for filters/readers from plugins. |
| Description | Add support for incorporate documentation for filters/readers from plugins. It must be noted that the documentation should be dynamically loaded when the plugin is loaded, paraview being oblivious of the plugin at compile time. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | |
| Attached Files | |
| Issue History |
| 2011-11-22 11:15 | Utkarsh Ayachit | New Issue | |
| 2011-11-22 13:58 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-11-22 13:58 | Utkarsh Ayachit | Status | backlog => todo |
| 2011-11-22 13:58 | Utkarsh Ayachit | Status | todo => active development |
| 2011-11-22 22:30 | Utkarsh Ayachit | Category | (No Category) => Feature |
| 2011-11-28 11:13 | Mike Jackson | Note Added: 0027734 | |
| 2011-11-28 11:28 | Utkarsh Ayachit | Note Added: 0027735 | |
| 2011-11-28 11:29 | Utkarsh Ayachit | Note Edited: 0027735 | bug_revision_view_page.php?bugnote_id=27735#r400 |
| 2011-12-02 16:45 | Utkarsh Ayachit | Topic Name | => 12745_help_from_plugins |
| 2011-12-05 13:21 | Utkarsh Ayachit | Note Added: 0027772 | |
| 2011-12-05 13:21 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2011-12-05 13:21 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2011-12-05 13:21 | Utkarsh Ayachit | Resolution | open => fixed |
| 2011-12-19 15:14 | Utkarsh Ayachit | Note Added: 0027835 | |
| 2011-12-19 15:15 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-12-19 15:15 | Utkarsh Ayachit | Note Added: 0027855 | |
| 2011-12-19 15:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| 2012-02-08 17:26 | Utkarsh Ayachit | Status | customer review => closed |
| 2012-02-08 17:26 | Utkarsh Ayachit | Note Added: 0028154 | |
(0027734)
Mike Jackson
2011-11-28 11:13
Does this mean that there is NO support in 3.12? Or can I adjust my code to compile in my help file directly into my plugin? |
(0027735)
Utkarsh Ayachit
2011-11-28 11:28
(edited on: 2011-11-28 11:29) |
There's no support in 3.12. The way the documentation is generated makes it really tricky to hack in a quick fix for 3.12.
(0027772)
Utkarsh Ayachit
2011-12-05 13:21
commit 97e7bf1c98aecf4cc3bff4ee7066419d552e4f38
Merge: 1bbb909 a7a4f65
Date: Mon Dec 5 13:20:03 2011 -0500
Merge topic '12745_help_from_plugins' into next
a7a4f65 Fix title for index page.
3c50229 Added Index and Search widgets to the help dialog.
503edef Help index was not refreshed when plugins were loaded.
69058d1 Added support to add html pages in plugins as documentation.
b978eab Added support to show proxy help for proxies loaded from plugins.
21aad08 Updating documenation as plugins are loaded.
4c88eb5 Added simple API to connect VTK events to QT slots/signals.
ef96341 Fixing the index.
512ea94 Minor cleanups.
a0651ab Added logic to automatically generate TOC when not provided.
1e101d5 removed obsolete code.
429aacb WIP: Started adding component to load docs from plugin.
19c2324 Added support to access binary resources from vtkPVPlugin.
bf5a65f Fixing geenration to work when empty prefix/suffix are provided.
08bdf81 WIP: Compiling the plugin help as a SM resource.
d8969a3 Fixes to ensure the functions work in different setups.
(0027835)
Utkarsh Ayachit
2011-12-19 15:14
merged into master (wherever applicable) |
(0027855)
Utkarsh Ayachit
2011-12-19 15:15
(0028154)
Utkarsh Ayachit
2012-02-08 17:26
closing bugs sitting in "customer review" for a long time. |
