MantisBT - VTK | |||||
| View Issue Details | |||||
| 0012744 | VTK | (No Category) | public | 2011-11-22 09:01 | 2016-08-12 09:55 |
| Reporter | David Partyka | ||||
| Assigned To | David Partyka | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | moved | ||
| Product Version | 5.8.0 | ||||
| Target Version | 5.8.1 | Fixed in Version | |||
| Project | TBD | ||||
| Type | incorrect functionality | ||||
| Summary | 0012744: VTKTargets installation location issues | ||||
| Description | Please review the following 4 changes. I think they might be helpful. * VTK_TARGETS_FILE was defined twice * adding #include <cstring> was necessary for gcc-4.6 On a Debian system I am installing into /usr/lib/ * VTKTargets.cmake gets installed in the same folder as the libs (in my case /usr/lib/ but I need them in /usr/lib/vtk-5.8) * libPath always points to /usr/lib/vtk-5.8 (please don't apply this patch, it's just to show you that something is wrong) Thanks Dominique --- vtk-5.8.0.orig/vtkGenerateVTKConfig.cmake +++ vtk-5.8.0/vtkGenerateVTKConfig.cmake @@ -147,9 +147,6 @@ SET(VTK_TCL_TK_MACROS_MODULE_CONFIG "${VTK_CMAKE_DIR}/vtkTclTkMacros.cmake") SET(VTK_CMAKE_EXTENSIONS_DIR_CONFIG ${VTK_BINARY_DIR}/CMake) -# Export Targets file. -SET(VTK_TARGETS_FILE "${VTK_BINARY_DIR}/${VTK_INSTALL_EXPORT_NAME}.cmake") - # Build configuration information. SET(VTK_CONFIGURATION_TYPES_CONFIG ${CMAKE_CONFIGURATION_TYPES}) SET(VTK_BUILD_TYPE_CONFIG ${CMAKE_BUILD_TYPE}) --- vtk-5.8.0.orig/Utilities/DICOMParser/DICOMParser.cxx +++ vtk-5.8.0/Utilities/DICOMParser/DICOMParser.cxx @@ -41,6 +41,7 @@ #include <string.h> #include <string> +#include <cstring> // Define DEBUG_DICOM to get debug messages sent to dicom_stream::cerr // #define DEBUG_DICOM --- vtk-5.8.0.orig/Utilities/LastConfigureStep/CMakeLists.txt +++ vtk-5.8.0/Utilities/LastConfigureStep/CMakeLists.txt @@ -11,7 +11,7 @@ #----------------------------------------------------------------------------- GET_PROPERTY(VTK_TARGETS GLOBAL PROPERTY VTK_TARGETS) EXPORT(TARGETS ${VTK_TARGETS} FILE ${VTK_BINARY_DIR}/${VTK_INSTALL_EXPORT_NAME}.cmake) -INSTALL(EXPORT ${VTK_INSTALL_EXPORT_NAME} DESTINATION ${VTK_INSTALL_LIB_DIR_CM24}) +INSTALL(EXPORT ${VTK_INSTALL_EXPORT_NAME} DESTINATION ${VTK_INSTALL_PACKAGE_DIR_CM24}) GET_PROPERTY(VTK_LIBRARIES GLOBAL PROPERTY VTK_LIBRARIES) #----------------------------------------------------------------------------- # Create the VTKConfig.cmake file containing the VTK configuration. --- vtk-5.8.0.orig/Wrapping/Tcl/pkgIndex.tcl.in +++ vtk-5.8.0/Wrapping/Tcl/pkgIndex.tcl.in @@ -5,6 +5,7 @@ package ifneeded vtkinit {@VTK_MAJOR_VER proc load_library_package {libName libPath {libPrefix {@VTK_TCL_LIBNAME_PREFIX@}}} { set libExt [info sharedlibextension] set currentDirectory [pwd] + set libPath /usr/@VTK_INSTALL_LIB_DIR@/ set libFile [file join $libPath "$libPrefix$libName$libExt"] if {[catch "cd {$libPath}; load {$libFile}" errorMessage]} { puts $errorMessage | ||||
| Steps To Reproduce | |||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2011-11-22 09:01 | David Partyka | New Issue | |||
| 2011-11-22 09:01 | David Partyka | Status | backlog => tabled | ||
| 2011-11-22 09:01 | David Partyka | Assigned To | => David Partyka | ||
| 2011-11-22 09:01 | David Partyka | Product Version | => 5.8.0 | ||
| 2011-11-22 09:01 | David Partyka | Target Version | => 5.8.1 | ||
| 2013-07-22 20:03 | Dave DeMarle | Status | tabled => backlog | ||
| 2013-07-22 20:03 | Dave DeMarle | Note Added: 0031263 | |||
| 2013-07-22 20:33 | Dave DeMarle | Status | backlog => expired | ||
| 2013-07-22 20:33 | Dave DeMarle | Note Added: 0031280 | |||
| 2016-08-12 09:55 | Kitware Robot | Note Added: 0037255 | |||
| 2016-08-12 09:55 | Kitware Robot | Status | expired => closed | ||
| 2016-08-12 09:55 | Kitware Robot | Resolution | open => moved | ||
| Notes | |||||
