MantisBT - ParaView | |||||
View Issue Details | |||||
0012639 | ParaView | (No Category) | public | 2011-10-10 17:04 | 2016-08-12 09:58 |
Reporter | Robert Maynard | ||||
Priority | high | Severity | minor | Reproducibility | have not tried |
Product Version | 3.12 | ||||
Project | Sandia | ||||
Topic Name | |||||
Summary | 0012639: Configuration with MESA enabled is a nightmare | ||||
Description | Currently you have to set the following flags to properly build with OSMesa. VTK_OPENGL_HAS_OSMESA is enabled. OPENGL_INCLUDE_DIR set to OSMesa library OPENGL_gl_LIBRARY is empty if you want offscreen rendering OPENGL_glu_LIBRARY set the to library built by OSMesa VTK_USE_X is turned off Ontop of that VTK_USE_X doesn't properly clear itself once it is toggled on, so if that happens you need to blow away the entire build directory. We really should have a single non advanced option which is ENABLE_OSMESA which does everything for the end user. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2011-10-10 17:04 | Robert Maynard | New Issue | |||
2011-10-10 17:08 | Alan Scott | Note Added: 0027561 | |||
2011-10-10 17:11 | Alan Scott | Note Added: 0027562 | |||
2016-08-12 09:58 | Kitware Robot | Note Added: 0038081 | |||
2016-08-12 09:58 | Kitware Robot | Status | backlog => closed | ||
2016-08-12 09:58 | Kitware Robot | Resolution | open => moved | ||
Notes | |||||
